Speaker Recommendations - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-10-2013, 12:30 AM - Thread Starter
JohnCHellblazer's Avatar
JohnCHellblazer is offline
post #2 of 8 Old 01-10-2013, 12:43 AM - Thread Starter
Maybe Ascend 340 lcr and 200 surrounds? So many choices
post #3 of 8 Old 01-10-2013, 03:03 PM - Thread Starter
Bump
post #4 of 8 Old 01-10-2013, 03:05 PM
afrogt's Avatar
Quoted: 1414 Post(s)
Liked: 968
You have provided absolutely no budget. Kinda hard to make recommendations without one.
Afro GT
afrogt is online now
post #5 of 8 Old 01-11-2013, 02:26 PM - Thread Starter
1000-2000 somewhere around that. The reciever is like 500 and depending on what sub around 500-800. So the closer to 1000 the bettero
post #6 of 8 Old 01-11-2013, 03:31 PM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
I suggest a pair of Def Tech Studio Monitor 55 speakers for your main speakers. They are excellent and run $300 each. The Pro Center 2000 will run $349 to go with them, and a pair of Pro Monitor 800s will finish it off for $120 each or so. Those are list prices and I am sure you can find them cheaper if you do some looking around.
For a subwoofer, the NHT B12D is excellent, for around $700, and the Klipsch RW12D is pretty good for $400...etc.
commsysman is offline
post #7 of 8 Old 01-11-2013, 03:39 PM
gtpsuper24's Avatar
Liked: 100
The Arx A1b has been getting alot of attention and seems to be well liked. Probably one of the best bang for the buck bookshelfs out there. http://www.theaudioinsider.com/manufacturers.php?mPath=13 The A1b has been praised for its performance even against more expensive highly regarded speakers.
A comparison thread with the A1b and the Ascend 170SE http://www.avsforum.com/t/1446006/ascend-acoustics-cbm-170-se-vs-arx-a1b
gtpsuper24 is offline
post #8 of 8 Old 01-11-2013, 05:39 PM
JimWilson's Avatar
Quoted: 1532 Post(s)
Liked: 2037
I'd second the Arx speakers. Amazing detail, can play loud and are dirt cheap to boot. The more I listen to them the more impressed I become.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is online now
Reply Speakers
