5.1 front speakers - no sound - AVS Forum | Home Theater Discussions And Reviews
Old 01-11-2013, 07:41 AM - Thread Starter
DustyInMemphis's Avatar
Hi all-
Although I am a newbie when it comes to AV, I'll do the best I can to describe my problem... Awesome website by the way.
Anyways, my Dad set up a Pioneer VSX 1020 about a year ago with 5 pod Boston Acoustics speakers. Three and the front and one at the back. As a music and movie lover I constantly used them. A day ago, I realised that the three front speakers were not working or producing any sound whatever. I can still get sound, as the two rear speakers work perfectly in the Ext. Stereo setting. The subwoofer also works fine. The only thing I can think of is the night before, which was the last time they were working - I hosted a party and let my friends play music through the Bluetooth adapter (while I tried to get some sleep!). Although I doubt they changed any settings, the only thing I can think of is that the speakers possibly blew as they couldn't handle the volume.
Any comments and feedback would be much appreciated,
Thanks a bunch
Marie
DustyInMemphis is offline
Old 01-11-2013, 07:47 AM
brendelac's Avatar
Quoted: 148 Post(s)
Liked: 83
I'm thinking it's probably a setting on the receiver that's been changed. Either that or something basic like the speaker wire being disconnected.
brendelac is offline
Old 01-11-2013, 07:55 AM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1798
Some quick debugging suggestions:
- Like most AVRs, the VSX-1020 likely has a "pure direct" or similar mode, which bypasses all processing modes. Select that mode to rule out some wonky audio mode.
- If you're still not getting any sound out of the front speakers, connect each of the front speakers to one of the two rear channels to rule out a blown speaker.
- If the speakers are fine, connect one of the rear speakers to each of the front channels to confirm that the channels are dead.
eljaycanuck is offline
Old 01-11-2013, 08:49 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Pretty hard to turn off the front speakers while the surround speakers are still working.
Check your speaker connections. Make sure all the wires are still connected on both the receiver and speaker terminals.
You might have to do a processor reset. Have no idea what it is for that receiver but I'm sure it is in the manual.
Afro GT
afrogt is offline
Old 01-11-2013, 08:54 AM
JD in NJ's Avatar
Liked: 36
It could be as simple as an A/B speaker switch set to B, with the Surround and B speakers being on the same terminals.
JD in NJ is offline
Old 01-11-2013, 08:57 AM
NewToHT's Avatar
I bet that's the issue. That has happened to me about 300 times.....and every time I do it I feel like a moron when I hit the stupid "A Speaker" button and it fires up....this is usually after troubleshooting EVERY possible issue....and pulling all of the wires out of my walls.....
NewToHT is offline
Old 01-11-2013, 06:54 PM - Thread Starter
How would one go about setting it back to A?
Old 01-11-2013, 08:11 PM
afrogt's Avatar
Liked: 755
Umm, look at your receiver front panel and push the Speakers button a couple of times. You'll figure it out.biggrin.gif
Afro GT
afrogt is offline
