Update or replace?? Calling on the AVS community - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-11-2013, 05:21 PM - Thread Starter
SicDub's Avatar
I'm just now making the transition from entry level surround sound to high fidelity listening. I've done much research but I don't have much experience under my belt.
The dilemma: I just bought a Pioneer Elite VSX-42 (rated at 80 watts per channel - 560 watts in total). I am very pleased with the receiver but now I want to 'add something' to the speaker department.
My current setup:
Center - JBL EC25
R/L - JBL E30's
Surround - JBL N26 ii's
Sub - Sony (Trash)
I'm turning to the AVS community for guidance. Do I replace all speakers or update the weakest links?
For around $700 I can buy JBL ES30's and a JBL ES250P. Using my existing E30's as surround speakers, this would leave me with a respectable home audio system.
OR
Should I cough up the dough and buy:
Center - RC42 II
R/L - RB51 II (The room will not support floorstanding speakers :-/)
Surround - RS42 II
Sub - RW12D
I'm sure I would be thrilled with the Klipsch reference series but the price is something to choke on.
Bottom line: I'm not convinced JBL offers genuinely high quality home audio equipment. Will there be a clear audible difference in Klipsch's reference series?
Any tips or suggestions will be much appreciated. Pictures upon request.
-Nick
SicDub is offline
post #2 of 7 Old 01-11-2013, 06:07 PM
gtpsuper24's Avatar
Liked: 99
What kind of budget are you looking at spending?
Several other brands are in the Klipsch price range
http://www.theaudioinsider.com/index.php?loudspeakers=arx&cPath=21_32& Personal favorite
http://www.htd.com/Products/level-three-speakers
http://www.hsuresearch.com/products/hb-1.html http://www.hsuresearch.com/products/hc-1.html
For subwoofers the RW12D is decent but something like SVS's PB1000 would easily outperform it especially in distortion numbers (much lower) and extension (much lower again).
http://www.svsound.com/1000-series-landing
gtpsuper24 is offline
post #3 of 7 Old 01-11-2013, 06:32 PM - Thread Starter
SicDub's Avatar
Well, I have about $1,000 to play with.
HSU seems like an awesome value and would definitely fit into my budget! Thanks!
I've read some scary articles about the damage under powering a speak can cause - will the 80 watts per channel the VSX-42 offers be enough to properly drive HB-1 MK2 bookshelf speakers? Will they deliver solid bass performance when listening to 2-channel music?
SicDub is offline
post #4 of 7 Old 01-11-2013, 07:02 PM
gtpsuper24's Avatar
Liked: 99
Your receiver should be fine. It would take some seriously inefficient speakers to cause trouble. Just stay with something 8ohms and 90+db sensitivity. The HSU's are awesome bookshelfs, I had a pair a little over a year ago and demo'd them a few days and they are very nice sounding, although I ended up keeping the Arx speakers and sending several others back. HSU probably would have been my next choice if they had matching towers, but thats the only bad thing I can say.
The HSU subwoofers are also great and you should be able to get the HSU speakers plus the subwoofer as a matching Hometheater package.
post #5 of 7 Old 01-12-2013, 02:09 PM - Thread Starter
SicDub's Avatar
Why Arx over HSU?
HSU's hybrid package 2 seems very nice.
I do about 70% gaming, 25% movies, and 5% music. The listening area is around 20' x 12'. Do you think the self powered 250 watt sub will be enough?
SicDub is offline
post #6 of 7 Old 01-12-2013, 02:45 PM
elmorage's Avatar
Liked: 49
I just bought the hsu 5.0 package and the rw12d sub and they really perform well in a room just like yours. Highly recommended, especially for movies and games. I keep tossing emp grenades in call of duty just to get the sub pounding and it shakes the whole house.
elmorage is offline
post #7 of 7 Old 01-12-2013, 02:54 PM
gtpsuper24's Avatar
Liked: 99
Originally Posted by SicDub View Post
Why Arx over HSU?
HSU speakers are a fantastic value and are nice speakers. I just liked the Arx speakers alitte more. The planar tweeter seemed more natural and better sounding to me and the woofers in the Arx had much more of a powerful bassier sound to them than the HSU. None of these attributes was drastically better over the other. In my room and with my ears I prefered the Arx.
Another closer on going with the Arx was I wanted a tower speaker for fronts eventually. HSU only offers the bookshelfs and i've read theres no plans to add anything else than whats currently offered, (although I don't currently keep upto date with HSU forums). Arx had one tower available at the time A3 with the A5 being released.
Reply Speakers
