Looking for center channel below 400.00?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 01-11-2013, 08:26 PM - Thread Starter
benca1's Avatar
What would u pic for 80% tv 20% movies!!! ?? Have two klipsch gallery g-12's as l/r but can upgrade those to if need be!!
benca1 is offline
post #2 of 18 Old 01-11-2013, 08:36 PM
afrogt's Avatar
Quoted: 1056 Post(s)
Liked: 757
Why not another G12 or G16 if you like your current speakers? They can be used as a left, center or right speaker.
http://www.crutchfield.com/p_714G16B/Klipsch-Gallery-G-16-Flat-Panel-Speaker.html
Afro GT
afrogt is offline
post #3 of 18 Old 01-11-2013, 08:38 PM - Thread Starter
benca1's Avatar
I hate the g-12's and g-16 !! I am using the g-16 now and want to throw it in trash
benca1 is offline
post #4 of 18 Old 01-11-2013, 08:41 PM
afrogt's Avatar
Liked: 757
Well then you post should be "I want 3 new front speakers", not just a center. You should have said you hate your current speakers in your original post.
What's your budget for 3 speakers and do they need to be the flat panel type?
Afro GT
afrogt is offline
post #5 of 18 Old 01-11-2013, 08:44 PM
Colm's Avatar
Liked: 94
Yep, another of the same would be the correct choice for a center. If you use something else, you will like your speakers even less than you do now.
Colm is offline
post #6 of 18 Old 01-11-2013, 08:48 PM - Thread Starter
benca1's Avatar
750.00? Ish would like to stay around there!! Doesn't have to be flat panel type!! Was looking at energy, Martin Logan, def tech and make sound!!
benca1 is offline
post #7 of 18 Old 01-11-2013, 08:49 PM - Thread Starter
benca1's Avatar
As a matter of fact I want the farthest thing from a flat panel speaker and at least 5 1/4 speakers in center
benca1 is offline
post #8 of 18 Old 01-11-2013, 08:51 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Three Ascend HTM200's will cost $470 shipped, and easily outperform those to small for their own good Klipsch's...
http://www.ascendacoustics.com/pages/products/speakers/htm200/htm200.html
If you're looking for bigger Ascend 170's, work. Also 3 Arx A2's would be a good choice
http://www.theaudioinsider.com/product_info.php?p=arx-a2b-center-lcr-loudspeaker&products_id=66&
Jay1 is offline
post #9 of 18 Old 01-11-2013, 08:51 PM
afrogt's Avatar
Liked: 757
Get 3 Energy V5.2C speakers from WWStereo. $510 for three speakers using promo code VER52WW
You can get black or rosenut
http://www.wwstereo.com/Energy/V5.2CPIANB
http://www.wwstereo.com/Energy/V5.2CPIANR
Afro GT
afrogt is offline
post #10 of 18 Old 01-11-2013, 08:58 PM - Thread Starter
benca1's Avatar
Sounds perfect to me !!! That's exactly what I was looking at!! Love this set up
benca1 is offline
post #11 of 18 Old 01-11-2013, 09:02 PM
afrogt's Avatar
Liked: 757
You can get 3 CBM-170's for about $40 more
http://www.ascendacoustics.com/pages/products/speakers/cbm170/cbm170.html
Or 2 CBM-170's and the 340SE center for about $650.
http://www.ascendacoustics.com/pages/products/speakers/cmt340c/cmt340c.html
The Energy V5.2's are a bargain though and look better too. Might even be able to upgrade your subwoofer with the remaining $240.
http://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M/ref=sr_1_1?ie=UTF8&qid=1357963587&sr=8-1&keywords=bic+f12
Afro GT
afrogt is offline
post #12 of 18 Old 01-11-2013, 09:04 PM - Thread Starter
benca1's Avatar
It is going below tv horizontal so need to stick with medium size of the first set smile.gif
benca1 is offline
post #13 of 18 Old 01-11-2013, 10:11 PM - Thread Starter
benca1's Avatar
Sub is basically new it's a velodyne vx-11!!! It's not actually bad
benca1 is offline
post #14 of 18 Old 01-11-2013, 10:14 PM - Thread Starter
benca1's Avatar
How long is this code good for ?? For energy
benca1 is offline
post #15 of 18 Old 01-12-2013, 01:48 AM
afrogt's Avatar
Liked: 757
Have no idea but the sale started right after Christmas. You can always call them on Monday.
You said you had $400 to spend on a center. $400 will get you 2 V5.2's if you don't have enough for a 3rd one right now. That's a least a good start. But if you really have up to $750 then you should get your 3 speakers now,.
I wouldn't wait long though. They had a sale similar to this on Energy V6.2 towers and they sold out quickly. Now they're nowhere to be found at all.
Afro GT
afrogt is offline
post #16 of 18 Old 01-12-2013, 03:31 AM
Szeppelin75's Avatar
+1 on the Veritas 5.2C. I ordered three for my front stage and coudn't be happier. Just check your tweeters when you get the speakers to see if any has dented domes. Some peo´ple have had problems with those. But excellent speakers and at that price it's a steal.
Szeppelin75 is offline
post #17 of 18 Old 01-12-2013, 03:51 AM
Bond 007's Avatar
Quoted: 2375 Post(s)
Liked: 1911
These are excellent speakers and made to be l/c/r
http://www.amazon.com/BIC-America-FH6-LCR-6-5-Inch-Frequency/dp/B0015A8Y3E/ref=sr_1_1?s=electronics&ie=UTF8&qid=1357987649&sr=1-1&keywords=bic+fh6-lcr
They are the same thing as these but 1 model year older in a different cabinet. I listened to them side by side and they sound identical.
http://www.amazon.com/BIC-Acoustech-PL-26-Center-Speaker/dp/B001VIRVOI/ref=sr_1_1?s=electronics&ie=UTF8&qid=1357987979&sr=1-1&keywords=bic+pl26
You could buy 5 of them with your budget and have a nice 5.1 setup. Don't let the price fool you. Read the reviews. These are nice budget speakers.
Licence to Kill
Bond 007 is offline
post #18 of 18 Old 01-12-2013, 11:31 AM - Thread Starter
benca1's Avatar
Purchased
benca1 is offline
Reply Speakers
