Just got hold of a higher quality center channel - but is it advisable to use with my setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-13-2013, 09:32 AM - Thread Starter
weeglos's Avatar
My reciever: Harmon Kardon AVR 254
My current center channel - Infiniti TSS 500 center
Right and left fronts: JBL 500
Sub: Infiniti TSS-500 Sub
Satellites: Infiniti TSS-500 Satellites
I just obtained a Cerwin Vega HT-CTR 4 ohm center channel speaker. Am I trading up if I swap my Infinity TSS-500 Center for the Cerwin Vega? Will my AVR 254 be able to drive the 4 ohm center OK? Will it damage my receiver or have any other adverse effects? I'm afraid to try it until I figure this out.
All the rest of the speakers in my setup are 8 ohm.
weeglos is offline
post #2 of 7 Old 01-13-2013, 10:24 AM
afrogt's Avatar
Quoted: 1055 Post(s)
Liked: 756
Your HK can handle 4 ohm loads, give it a try. CV speakers generally have a high sensitivity too which will make the easier to drive.
Afro GT
afrogt is offline
post #3 of 7 Old 01-13-2013, 10:35 AM
neuspeed94's Avatar
It might be a slight upgrade, but I don't think you will notice much improvement at all. I would just stick with the Infinity for 8ohm consistency if I were you. Now if you came across a JBL 500 center, then I would say of course that's an upgrade, if anything the timbre matching will sound better.
neuspeed94 is offline
post #4 of 7 Old 01-13-2013, 11:16 AM - Thread Starter
weeglos's Avatar
The Infinity TSS-500's I have came in a 5.1 kit. The satellites are.... ok, but a little tinny for my taste. The center is better, but still a bit tinny. This Cerwin Vega is a beast - it has two six inch cones, a tweeter, and a port. It should have much better frequency response than the Infinity center. I'd really like to use it, but am afraid of what it will do to my AVR.
Oh well. Got a call in to HK about it, as well as CV. I'll see what they say about it.
weeglos is offline
post #5 of 7 Old 01-13-2013, 11:34 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Plug it in and try it out, its not like your receiver's gonna go up in smoke...
Jay1 is offline
post #6 of 7 Old 01-13-2013, 12:29 PM
afrogt's Avatar
Liked: 756
Are you seriously gonna wait for HK to call you back? That could take days. Just plug the speaker in and try it!
I've got a HK 325 which has the same power ratings as your 254 or maybe less. You'll be okay trying using a 4 ohm speaker. Are you planning to play at max volume all day long?
Afro GT
afrogt is offline
post #7 of 7 Old 01-13-2013, 04:57 PM
Elihawk's Avatar
Quoted: 1016 Post(s)
Liked: 860
The cv will likely sound beter...but how will it sound with mismatched front speakers? Not sure having a center channel that can hit lower than your front L/R makes a lot if sense. However, if you like it, pick up a set of crewin vega towers upfront!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
Reply Speakers
