Bose Cinemate II vs. custom 2.1 with Denon AVR-1312, Def Tech Promonitor 800, and Dayton Sub-1000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 01-15-2013, 05:50 PM - Thread Starter
BMD004's Avatar
Ok, I made a thread the other day about how my dad was going to buy the Bose Cinemate II 2.1 system for $600. I told him to wait, and let me find some better options first if I can. He agreed. I made a thread here, and got some good advice. So here is what I came up with:
Denon AVR-1312 receiver. $200
Definitive Technology Promonitor 800 speakers: $290 (pair)
Dayton Sub-1000 10" Subwoofer: $110
Total: $600
OR,
Bose Cinemate II: $600
Is that a good set-up? Anything better? Any other recommendations?
BMD004 is offline
post #2 of 15 Old 01-15-2013, 05:58 PM
eljaycanuck's Avatar
Quoted: 1346 Post(s)
Liked: 1962
- Factory re-furb Denon AVR-1612 from accessories4less.com ($200). (The 1612 has Audyssey MultEQ; the 1312 has no room-correction software of any kind.)
- Cambridge S30s from Amazon.com ($220/pr.).
- +1 on the $110 Dayton SUB-1000 (unless you can wait for the $130 SUB-1200 to be back in stock).
Total: $530 (or $550 w/ the SUB-1200).
eljaycanuck is offline
post #3 of 15 Old 01-15-2013, 06:06 PM - Thread Starter
BMD004's Avatar
Those Cambridge speakers look kind of big... are they? We're a little limited on space.
Our TV sits in one of those recessed wall cut-out areas of the living room.. similar to this:
So the speakers are going to be in front of the TV on each side of the TV.
BMD004 is offline
post #4 of 15 Old 01-15-2013, 06:07 PM
jevans64's Avatar
Quoted: 204 Post(s)
Liked: 159
Keep hitting up Newegg daily to check the price of the Definitive Technology SM 450 for $280 - $300 a pair. They'll smoke BOTH the DefTech ProMonitor 800 and Cambridge S30. I'd also take a chance on a refurbished Denon AVR-1612 over the 1312. Extended warranty is $30 to $50 more for 3 to 5 years.
Newegg has been playing price ping-pong with the DefTech SM350 and SM450 for MONTHS now. Might be $280 a pair tomorrow. rolleyes.gif
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #5 of 15 Old 01-15-2013, 06:14 PM
jevans64's Avatar
Quoted: 204 Post(s)
Liked: 159
Hard to tell from the picture, but it looks like you only have 4" of clearance on each side of the TV. It is going to be TOUGH to get decent speakers that will fit.
Have you thought about adding a shelf on the left side of the TV to support the left speaker and use the cubby on the right for the other speaker?
Another option is to get on-wall speakers and mount them on the supports on each side of the TV. They look thick enough for on-wall speakers.
jevans64 is offline
post #6 of 15 Old 01-15-2013, 06:16 PM
Liked: 1962
"Big" is a relative term. IMO, they're pretty small: 8.9" (h) x 6.3" (w) x 9.2" (d).
They really should go here:
But if that's not feasible, skinny speakers will have to do.
post #7 of 15 Old 01-15-2013, 06:17 PM
zieglj01's Avatar
Quoted: 1680 Post(s)
Liked: 1582
Since your cabinet is limited - you need small type speakers >
Look at a pair of Acoustic Energy Aego T speakers
Good close out pricing
http://www.accessories4less.com/make-a-store/item/ACENAEGOTSAT/ACOUSTIC-ENERGY-AEGO-AE12-10-T-Series-4in-Satellite-Speaker-Black-Each/1.html
Mordaunt Short Carnival 9 subwoofer >
A real good closeout price
http://www.accessories4less.com/make-a-store/item/MORDCARN9CAL/MORDAUNT-SHORT-Carnival-9-10-100-Watt-Powered-Subwoofer-Calvados/1.html#!more
And the Denon 1612 receiver
__________________________________________
Who AM I
Speakers -- Snell K7 > Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is offline
post #8 of 15 Old 01-15-2013, 06:31 PM - Thread Starter
BMD004's Avatar
Well, that isn't a picture of our living room. It's only similar. Here are some pictures of our actual living room:
I'm not sure where I can put the speakers other than getting a couple of stands...
BMD004 is offline
post #9 of 15 Old 01-15-2013, 06:39 PM
Liked: 1962
My bad.
I'd go with a good pair of bookshelf speakers on stands - or a good pair of on-wall speakers - flanking the TV. But if that's not feasible, go with the skinny speakers. Sometimes, the limitations just can't be overcome.
post #10 of 15 Old 01-15-2013, 06:43 PM
zieglj01's Avatar
Liked: 1582
Look at the Center Stage brackets - to go over the TV
http://www.crutchfield.com/p_769CSB1005/Center-Stage-CSB-1005-ADJ.html
Who AM I
zieglj01 is offline
post #11 of 15 Old 01-15-2013, 08:02 PM - Thread Starter
BMD004's Avatar
That seems like a really good idea. It might look a little funny, but it is functional.
BMD004 is offline
post #12 of 15 Old 01-15-2013, 08:08 PM
zieglj01's Avatar
Liked: 1582
With some decent sound, you can get use to it.
Who AM I
zieglj01 is offline
post #13 of 15 Old 01-16-2013, 02:12 AM
jevans64's Avatar
Quoted: 204 Post(s)
Liked: 159
Only problem with those Center Stage brackets is that it is going to put the speakers way too close together. That is going to make for very poor imaging. Too bad there aren't cubbies on the left side. The designer of that A/V space gets an F.
What I would do is get a couple of speaker stands and put one right under the light switch and the other under the painting. Something like the Sanus NF30B, which is a 30" stand. I'm going to assume the light switch is at the standard height of 48", so that means the bottom of the plate is at 44". A 30" stand would give you 14" of clearance for a bookshelf speaker. The next stand height down is 26", but 30" would put the speaker at about the right height from the floor if you choose the average bookshelf speaker with 5.25" or 6.5" driver. Polk Monitor 35B, KEF C3, or DefTech SM350,45,450,55 should all fit nicely on the 30" Sanus stand.
jevans64 is offline
post #14 of 15 Old 01-16-2013, 03:22 AM
Browninggold's Avatar
Liked: 37
Here you go $500 with discount code..excellent company to deal with. http://www.wwstereo.com/Cart
Talk with Ira he's great.
See if you can get the next model up Denon AVR 1713 I believe that has Audyssey...probably around $50-$75 more.
"We can complain because rose bushes have thorns or rejoice because thorn bushes have roses". - Abraham Lincoln
Browninggold is offline
post #15 of 15 Old 01-16-2013, 08:47 AM
zieglj01's Avatar
Liked: 1582
You have room to wall-mount some flat panel speakers >> they are nice and will
not stick out to much from the wall - they do sound good, and some color options.
HTD Flat Panel
http://www.htd.com/Products/flat-panel-speakers/flat-panel-speaker
Who AM I
zieglj01 is offline
Reply Speakers
Denon Avr 1312 Receiver
