Budget Entry Level - Dayton B652/Monoprice Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 44 Old 01-15-2013, 08:03 PM - Thread Starter
lurch0101's Avatar
I'm trying to move away from the $30 logitech speakers and looking for some decent sound and looking to spend up to $150. my main goal is get the best bang for the buck.
Do any of you guys know if there is a huge difference between the dayton b652 and the monoprice 6 1/2 bookshelf pair ? If not i'll probably go with the monoprice because they're a little bit cheaper.
I recently had eagle tech ar508 which sounded better than anything i've owned. i accidentally broke them and now I can't go back to the tv speakers which sound horrible.
so far I've sort of narrowed it down to the following:
Would any of the following sound better a level above Dayton/Monoprice bookshelf?
Sony SS-B1000 -
Fluance SX6 - (currently $80)
Pioneer SP-BS22
Polk T15
I eventually want to work my way towards a mid range 5.1 setup. The speakers I just mentioned, would I be able to use any of them as my rear speakers?
thank you for any advice
lurch0101 is offline
post #2 of 44 Old 01-15-2013, 08:06 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Hands-down, my choice is Pioneer
lurch0101 likes this.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #3 of 44 Old 01-15-2013, 08:09 PM - Thread Starter
lurch0101's Avatar
They go for $90 now but were on sale for about $50 a few weeks back. I wish I had started looking into speakers back then eek.gif
post #4 of 44 Old 01-15-2013, 09:12 PM - Thread Starter
lurch0101's Avatar
also how come some people chose to build a system this way instead of just buying pre-packaged logitechs etc?
post #5 of 44 Old 01-15-2013, 09:24 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
This is what you said >
"I'm trying to move away from the $30 logitech speakers and looking for some decent sound and looking to spend up to $150.
my main goal is get the best bang for the buck."
Most of us build a system to get better quality, and to prevent buyer's remorse.
Who AM I
zieglj01 is offline
post #6 of 44 Old 01-15-2013, 09:29 PM - Thread Starter
lurch0101's Avatar
Someone suggested that I should just get the Swan M10s instead of building a system.
Do you think the studiophile av 40 are decent if bought for $100? I see they usually go for $140ish.
post #7 of 44 Old 01-15-2013, 09:31 PM
Dennis Murphy's Avatar
Quoted: 397 Post(s)
Liked: 581
I haven't heard the Monoprice entry. But I have extensive experience with the Daytons. There's a long thread about them on Audioholics:
http://forums.audioholics.com/forums/loudspeakers/83572-dayton-measured-stereophile-what-what-3.html
Briefly, the pair I bought recently were too probematic to recommend even at their dirt cheap sales price. The tweeter ouput was seriously attenuated, which just made the uncontrolled woofer breakup (the woofer runs free--no crossover) that much more apparent. They sound kind of cool when you first fire them up--a very full sound with lots of apparent detail--but then your ears start hurting. I came up with a $20/pr crossover mod that fixes the problem and produces very decent sound, but most people aren't going to want to bother with that. I would scrape up a few extra sheckles and get something with a real crossover. I also haven't heard the Pioneers, but I suspect they're a big step up.
Dennis Murphy is offline
post #8 of 44 Old 01-15-2013, 09:33 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I would rather build a system - however, if on a tight budget - then I would take the Studiophile 40 over
the Dayton speakers.
Who AM I
zieglj01 is offline
post #9 of 44 Old 01-15-2013, 10:17 PM - Thread Starter
lurch0101's Avatar
What would you recommend in the $150 range. The dayton setup would cost around $75 but I can go up to $150.
http://www.musiciansfriend.com/pro-audio/m-audio-studiophile-av-40-red-edition $100 with $20 off with 1 day left in sale. I'm going to go check out the pioneers at best buy tomorrow and see how it really sounds.
post #10 of 44 Old 01-16-2013, 09:06 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3074
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #11 of 44 Old 01-16-2013, 09:15 PM - Thread Starter
lurch0101's Avatar
went to best buy today and heard the pioneers and the bass was a bit too much. maybe it's because the way they have their speakers setup. also they were next to some $250 klipsch which didn't help either.
ps. walked out with a $50 BB GC for trading in old flip phones
post #12 of 44 Old 01-16-2013, 09:37 PM
cel4145's Avatar
Quoted: 2652 Post(s)
Liked: 2984
They could easily have some kind of loudness set or EQ cranked up. Best Buy is not know for having their speakers setup well, and since people don't usually characterize the Pioneers as being bass heavy, blaming Best Buy seems the best option. (lol)
I would imagine Best Buy would let you return them (I think they do), so you could always get your amplifier first, then get the speakers and see how they sound in your home.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #13 of 44 Old 01-18-2013, 08:48 AM - Thread Starter
lurch0101's Avatar
I was able to pick up Pioneer SP-BS21-LR for $40 from newegg. Is there a huge difference from Pioneer SP-BS21-LR to Pioneer SP-BS22-LR ?
I know that lepai 2020 is not the best choice for an amp but will it provide some decent sound with the SP-BS21 ?
thanks
post #14 of 44 Old 01-18-2013, 11:12 AM
cel4145's Avatar
Liked: 2984
thanks
That's a fantastic bargain for those. Your "$60" set with the Lepai and the Pioneers will outperform many (if not all) $150 desktop multimedia speakers in SQ.
post #15 of 44 Old 01-18-2013, 11:15 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
thanks
I think the BS22 sounds better but you're not gonna get a pair for $40. Paired with the Lepai 2020A+ amp you've got a nice setup for $60-$70.
Afro GT
afrogt is offline
post #16 of 44 Old 01-18-2013, 05:26 PM - Thread Starter
lurch0101's Avatar
I'm torn between the lepai 2020 and the Lepai LP-A68 (comes with remote). all the reviews say 2020 sounds a little bit better but I really need a remote to control the volume for the tv. i've been googling "t amp" "tripath amp" etc but theres like nothing that comes with a remote for under $50. yes there are 2.0 receivers for like $80+ but i'd rather just get a full fledged receiver down the road (2-3 months to complete 5.1). any suggestions ?
thanks
post #17 of 44 Old 01-18-2013, 06:07 PM
afrogt's Avatar
Liked: 755
I'm listening to my Lepai 2020 right now with a couple of Jamo A340 speakers here at work. Sounds real good for my purposes.
Well, if you need a remote then get the LP-A68.
Afro GT
afrogt is offline
post #18 of 44 Old 01-19-2013, 01:16 PM - Thread Starter
lurch0101's Avatar
So I saw a deal for the polk psw10 for $60 and I bought it. I know it has port chuffing problems but I wont be playing anything loud and its in small to a medium sized room(nyc size). seems like a good buy...now i just need an amp.
post #19 of 44 Old 01-19-2013, 04:53 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3074
That's kind of a "one-note" subwoofer. Although, there isn't anything out there for $60. If it's an option, I would return that sub and take a look at the budget subwoofer thread in the subwoofers forum.
post #20 of 44 Old 01-23-2013, 02:50 PM - Thread Starter
lurch0101's Avatar
I just received the speakers and the amp. So i plugged in the wires + to + and - to -.
these wires are going from the amp to the speaker. when I turn the amp on the sound is very very low and if i turn up the volume the amp makes a clicking sound. if i go past "12 o clock" dial no sound comes out of the speakers at all. can it be a faulty amp? i haven't received the sub yet which comes in tomorrow.
what am I doing wrong?
thank you
post #21 of 44 Old 01-23-2013, 02:57 PM
Quoted: 397 Post(s)
Liked: 581
Hmmm Make sure no strands of wire at the receiver end are touching each other. It sounds like a partial short. There's certainly no problem with the hook-up you show in the pic.
post #22 of 44 Old 01-23-2013, 03:31 PM - Thread Starter
lurch0101's Avatar
unooked and hooked everything back in and still having the same problem :/
post #23 of 44 Old 01-23-2013, 04:58 PM
cel4145's Avatar
Liked: 2984
I find that above 12 o'clock on the dial (others say good to about 1 o'clock) that the Lepai starts to distort. You should be able to hear it fine well before then.
In addition to checking for shorts, do you have a different cable you can try for connecting to your source? And what is your source?
post #24 of 44 Old 01-23-2013, 05:24 PM - Thread Starter
lurch0101's Avatar
i tried using these cables. also tried a couple of different power supplies.
lets say I leave the dial at 10 oclock and turn up the volume from my iphone, it starts to make a clicking noise and the volume goes in and out. the volume is low as in you literally have to be a foot away at most to be able to hear anything.
i'm using this 16 gauge wire
post #25 of 44 Old 01-23-2013, 09:05 PM
cel4145's Avatar
Liked: 2984
Definitely sounds like something inside is not working. Some kind of short.
post #26 of 44 Old 01-26-2013, 01:17 PM - Thread Starter
lurch0101's Avatar
got another amplifier yesterday and pretty much the same problem :/
going to best buy to pick up a receiver like this one from best buy in final hopes.
post #27 of 44 Old 01-26-2013, 01:20 PM
cel4145's Avatar
Liked: 2984
Have you tried putting your iPhone volume on 85-90% of max, and then slowly turning up the Lepai?
post #28 of 44 Old 01-26-2013, 01:24 PM - Thread Starter
lurch0101's Avatar
yep, tried all sorts of combinations. do you know if this receiver will work for the pio?
post #29 of 44 Old 01-26-2013, 01:35 PM
cel4145's Avatar
Liked: 2984
All I can say is that I've never seen anyone on here recommend an Insignia receiver. Ever. eek.gif
The Sherwood receivers available on Amazon is what I would look at for around $100. Although your best bet is to look on your local Craigslist and see if there are any used Pioneer, Denon, Yamaha, Onkyo, or Kenwood receivers.
post #30 of 44 Old 01-26-2013, 01:37 PM - Thread Starter
lurch0101's Avatar
the receiver is just so I can test the speakers again before sending them back. was just going to buy the receiver, bring it home and return it the next day.
Reply Speakers
