Newb needs help picking out speakers - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 37 Old 01-18-2013, 01:07 PM
losservatore's Avatar
Quoted: 2566 Post(s)
Liked: 2351
you want small speaker recommendation here is one.
cambridge sound works have a sale right know http://store.cambridgesoundworks.com/
OPEN BOX SALE! Save 30% on OPEN BOX Units! Enter promo code OPENBOX2 at check-out, to purchase an OPEN BOX unit, and you will save 30% off the regular price. All OPEN BOX units are brand new, factory resealed. Limited inventory BUY NOW!
losservatore is offline
post #32 of 37 Old 01-18-2013, 01:09 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
Originally Posted by JerryLove View Post
^^^Both posts above: You are preaching to the choir; though I appreciate that you took the time to type it out biggrin.gif
Though, actually, 86db would be near (higher than actually) THX requirements for sustained sound.
Your words: sustained sound. If the sustained SPL is 86 dB, your speakers need to handle peaks as much as 20 dB greater than that.
My partiuclar 5" drivers are in a pair
Usng a pair is good for 3 dB more than a single speaker.
and coupled with a MWTL cabinet and will put out somewhere around 108db (@1m) at 38Hz before hitting xmax.
You've got me (and google) there. What is MWTL?
All I've said is that no speaker has a minimum frequency at which it can be moved. What it does have is a potentially severe SPL limitation. It's amazing how much my completely true statement generates disagreement.
I believe that the numbers I provided above are 100% substantiation for the idea that all speakers have inherent SPL versus frequency limits. If that is what you are saying then we agree.
I don't know about some of the rest of the chatter I see in the thread, though! ;-)
arnyk is offline
post #33 of 37 Old 01-18-2013, 01:18 PM
Liked: 2351
please he needs help with small speakers take the science discussion to other thread.
jbdan and theproman23 like this.
post #34 of 37 Old 01-18-2013, 01:29 PM
JerryLove's Avatar
Liked: 82
given that the OP did not actually ask about a small speaker set, you may want to check the log in your eye.
On the topic? Get a pair of the Pioneers currently getting raves and spend the rest on a sub.
There will be no answer better than that other than to go listen for yourself. That's the only *real* advice.
JerryLove is offline
post #35 of 37 Old 01-18-2013, 01:31 PM
JerryLove's Avatar
Liked: 82
I think my point was that it was likely audible.
Mass weighted transmission line.
Yes we agree.
post #36 of 37 Old 01-18-2013, 01:38 PM
Knight Operator's Avatar
Jamo, look on amazon theyre having a sale for 5.1. many options in your price range. made by klipsich.
BIC america next step up. check them out. thats what i have.
Knight Operator is offline
post #37 of 37 Old 01-18-2013, 01:38 PM
Liked: 2351
Originally Posted by theproman23 View Post
Thanks everyone for the awesome feedback.
I would love to have bigger speakers or towers but my living room situation just doesn't accomodate them. Given that I can't turn up the bass about 75% of the time, given the thin floor boards and downstairs neighbors, I am thinking about sticking to the smaller speaker setup with a decent sub.
I've narrowed it down to the Energy Classic 5.1, Energy RC-Micro 5.1, Mirage Nano Sats and MLT2s.
They're all priced about the same on Cructhfield so would greatly appreciate your feedback on them!!
do you think that he really care about the science conversation?rolleyes.gif
neuspeed94 likes this.
Reply Speakers
