Can i use any wire as speaker cable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-16-2013, 01:32 PM - Thread Starter
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
I'm aware it's better to use larger cabling when possible and that was my original plan until i found out my receiver plugs aren't cut to receive much better than 18 guage. I have some red primary wire and some sort of blue wire lying around, my dad uses it mostly for wiring in cars.
Is it safe to use one kind of wire for both the main and ground wires? Does it matter if it's copper or otherwise?
Mik James is offline
post #2 of 6 Old 01-16-2013, 03:14 PM
neuspeed94's Avatar
You want to use 100% copper speaker wire.
neuspeed94 is offline
post #3 of 6 Old 01-16-2013, 03:49 PM - Thread Starter
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
I want to or i have to?
post #4 of 6 Old 01-16-2013, 04:27 PM
Bill Fitzmaurice's Avatar
Liked: 4630
Bill Fitzmaurice is offline
post #5 of 6 Old 01-16-2013, 04:48 PM - Thread Starter
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
Thanks For the info, I had a feeling wire is wire. Anyways I dug up some 18 gauge Grote
Brand primary wire in both black and red (convenient), the cable run is only 3' right now for testing at low volume. The jacks on the amp are just spring jacks and seem to be pretty well limited to a max of 16 gauge wire.
post #6 of 6 Old 01-16-2013, 08:50 PM
skriefal's Avatar
Quoted: 85 Post(s)
Liked: 69
You don't have to. But if you choose to use CCA (copper-clad aluminum) wire, keep in mind that it's less efficient at carrying a signal than same-gauge copper wire. e.g. 16-gauge CCA wire is equivalent to 18-gauge copper wire, 14-guage CCA is equivalent to 16-gauge copper wire, etc. Radio Shack may still carry real copper wire, but other local stores (Home Depot, Walmart, Target, etc) may have only CCA wire. If the packaging does not state "pure copper", or "XX% OGC", etc, then assume that it is CCA.
skriefal is offline
Reply Speakers
