How are these for a small room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-16-2013, 08:08 PM - Thread Starter
m_ajmera's Avatar
I am looking for a 5.1 system for a smallish room mostly for movies and TV. I came across BOSTON ACOUSTICS Classic Series 2300 II 5.0 - available at accessories4less.com for $300. I can probably spring another $300 for a sub. Are these reasonably OK? I know that the size of the speakers will put a limit on what I can expect in terms of sound quality, but this is the absolutely the upper end in terms of size of what I can get for this room.
My other alternatives are
- Energy Take 5.1
- Def Tech Procinema 600
- MTL - 2
Any opinions or suggestions?
Mayank
m_ajmera is offline
post #2 of 8 Old 01-16-2013, 08:13 PM
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 36
Not a big fan of the mini-sats. Allot better can be had unless you absolutely must go with the mini-sats.
Newbie01 is offline
post #3 of 8 Old 01-16-2013, 09:29 PM
zieglj01's Avatar
Quoted: 939 Post(s)
Liked: 846
Acoustic Energy
http://www.accessories4less.com/index.php?page=search&search_query=Acoustic+Energy+Aego
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #4 of 8 Old 01-17-2013, 05:36 AM - Thread Starter
m_ajmera's Avatar
You think these would be better than the ones I chose?
Another option I came across is to do get 4 HTD Middys and 1 HTD Flat Screen for center channel.
The room that these will be in is very small and therefore the speakers have to be low profile.
m_ajmera is offline
post #5 of 8 Old 01-17-2013, 09:58 AM
zieglj01's Avatar
Quoted: 939 Post(s)
Liked: 846
I favor the Acoustic Energy - I have owned some of their speakers before, they are well built and
they sound real nice
I have also owned HTD speakers and the Flat Panel is a good one - I would prefer 3 Flat Panels
for the fronts, and the Middy for surrounds. If you can not do 3 Flat Panels up front, then I would
go Acoustic Energy over them.
Acoustic Energy Aego T review
http://www.avreview.co.uk/news/article/mps/uan/1063
Who AM I
zieglj01 is offline
post #6 of 8 Old 01-17-2013, 10:13 AM
Elihawk's Avatar
Quoted: 1016 Post(s)
Liked: 861
Satellite systems have two problems...limited output (volume) and no or limited bass and mid bass. Even in small room, where I don't need much output, I still want decent bass!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
post #7 of 8 Old 01-17-2013, 12:49 PM - Thread Starter
m_ajmera's Avatar
Would you suggest using the same for center channel?
m_ajmera is offline
post #8 of 8 Old 01-17-2013, 12:56 PM
zieglj01's Avatar
Quoted: 939 Post(s)
Liked: 846
Yes, that is the way to go for the center
Who AM I
zieglj01 is offline
Reply Speakers
