Klipsch RF-3 II Damaged Woofer Cone - AVS Forum | Home Theater Discussions And Reviews
Old 01-16-2013, 09:29 PM - Thread Starter
Huck43's Avatar
I have a Klipsch 5.1 system including some RF-3 II floorstanding mains. I have not used the grills and have been fortunate until recently when my nephews damaged one of the cones by kicking a small ball inside. This was the result:
http://oi45.tinypic.com/wkfwj7.jpg
Now, trying to search on this issue, the only thing I really came up with is the dust cap being dented, but that is not the issue. Couple of questions, is it worth replacing this (assuming it is fairly easy as I have no experience with speaker repair), or will it not affect sound quality and simply putting on the grills now will be good enough to hide the problem and prevent future issues.
As for a replacement, searching ebay, I was able to find this:
http://www.ebay.com/itm/Klipsch-K-1083-SV-RF-35-Replacement-Woofer-Part-No-120861-/300837274393?pt=US_Speaker_Parts_Components&hash=item460b4c8319
http://www.ebay.com/itm/Klipsch-K-1083-SV-Woofer-Part-No-120856-/300760670711?pt=US_Speaker_Parts_Components&hash=item4606bba1f7
However, the model number is slightly different from the K-1083-SB (V instead of B) listed on the product page on
http://www.klipsch.com/rf-3-ii-floorstanding-speaker
Also, the part no is also different between the two listings.
Any advice is appreciated. Thanks.
Huck43 is offline
Old 01-17-2013, 03:37 AM
Kain's Avatar
Quoted: 1201 Post(s)
Liked: 329
Have a look at this thread and start reading from the post that is third from the bottom.
http://community.klipsch.com/forums/t/170253.aspx
Kain is offline
Old 01-17-2013, 03:40 AM
Kain's Avatar
Liked: 329
By the way, in case you want to buy a K-1083-SB, have a look here: http://reconingspeakers.com/products-page/brands/klipsch-rf3-k-1083-8-woofer/
Kain is offline
Old 01-17-2013, 07:25 AM - Thread Starter
Huck43's Avatar
Thanks for that link.
So is it fairly easy to replace these and do you recommend doing it? I assume removing the four screws and disconnecting a couple wires is all that is required. Is that safe to say or will I be in for some surprises? Thanks.
Huck43 is offline
Old 01-17-2013, 12:33 PM
Kain's Avatar
Liked: 329
I asked the same question on the Klipsch forums. I too need to replace a driver in my RC-7.
Have a look at the second post on page 2 of this thread: http://community.klipsch.com/forums/t/169337.aspx?PageIndex=2
Replacing the woofer is easy. Just unscrew it and remove it. The wires are attatched with spade connectors. Be careful when removing though as the drivers are MUCH heavier than they look.
Kain is offline
Old 01-17-2013, 01:15 PM - Thread Starter
Huck43's Avatar
Oh, seems easy enough then.
My only last question would be, would you expect the damage to affect the sound quality of the woofer drastically? If it is not a huge deal, I can always just leave it covered behind the grill and save the cash.
Thanks for all the help and info!
Huck43 is offline
Old 01-17-2013, 01:48 PM
Kain's Avatar
Liked: 329
You're welcome!
As for your last question, honestly I am not sure. As far as I know, if the black dust-cap in the middle is damaged, then it is not much of an issue. But if the copper-colored part/actual woofer is damaged, then it is a more serious issue. Not sure though! Hopefully someone will be able to help you out on that part.
Kain is offline
Old 01-17-2013, 08:32 PM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
That looks severely damaged, the woofer cone appears out of shape. I doubt it moves freely in and out any longer. It really needs to be replaced.
jdcrox is offline
