how long is a typical "break-in period" for speakers? - Page 3 - AVS Forum
post #61 of 68 Old 03-27-2014, 02:07 PM
Bill Fitzmaurice's Avatar
Liked: 1195
Originally Posted by Tzuky View Post
Interesting I believe I have been told or read somewhere that it is not good to play speakers loud in the first 30-40 hours at least
That's typical myth morphing of the truth of the matter, which is that some drivers, woofers in particular, may take up to 40 hours use before the suspension fully softens and it works as well as it's able to.
Bill Fitzmaurice is online now
post #62 of 68 Old 03-28-2014, 08:47 AM
Tzuky's Avatar
I guess this is the case... I do believe in starting easy just to be safe and I know it does not make sence since all speakers are factory tested close to their limits but anyways thank you all for the input and info and articles!
Tzuky is offline
post #63 of 68 Old 03-28-2014, 01:36 PM
Liked: 1195
If only. Most are simply function tested to be sure they work.
post #64 of 68 Old 03-28-2014, 02:06 PM
Tzuky's Avatar
well since they are tested even tho simple if they work.. that means if you open the box at home hook the speaker to amp and turn the volume high for their first song.... they are not going to break or sound worse after that.. the guy who installed the Kicker subwoofer (Kicker Comp 10 150W on a Kenwood 200W amp) blasted it to the fullest when he was adjusting the settings for more than a few seconds more like 3-5 minutes and the speaker is in quite good shape today.. that was 3 years ago... so I mean if a speaker is working at the start there is nothing much you can do to brake it right out the box.. exept huge overpowering... this is just stupid but everything else is just normal
Tzuky is offline
post #65 of 68 Old 03-29-2014, 07:17 AM
Liked: 1195
I break in my woofers overnight, using a 20-25Hz sine wave at 8 to 12 volts, ie., about 10 watts. The low frequency used fully flexes the suspension with a small signal level, and since I do so before mounting the woofer the process is inaudible. All manufacturers should do so, not only to break the woofer in, but also to weed out any defective units. Few do, because this takes time, and labor, and both of those factors add to cost.
Tzuky likes this.
post #66 of 68 Old 03-29-2014, 09:35 AM
InABox's Avatar
The manual for my energy RC-70 says 100 hours to let thing "loosen" up to prevent internal damage at high volume. I put the TV to a jazz channel and walked away when I was not watching TV with them on. 4 and a half days of them on.
InABox is offline
post #67 of 68 Old 03-29-2014, 09:56 AM
Tzuky's Avatar
Interesting... I do not play my Diamons at high volume a lot... actualy I just tested `em yesterday but they already had more that 50 hours... so I guess I`m good lol.. tha manual says nothing about break in
Tzuky is offline
post #68 of 68 Old 03-29-2014, 10:03 AM
Tzuky's Avatar
What you do is a great method I guess... and you are right all this is too expensive for the mass produced speakers
Tzuky is offline
Reply Speakers
User Tag List
