5.1 surround sound with minimalist look - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-18-2013, 01:04 PM - Thread Starter
gbandi's Avatar
I am setting up a home theater in our basement. The room is 15x15 space which opens to the left to a large space 15x26 and to the back to a 10x10 space with stairs. The ambient light is minimum at night which is when i plan to use it mostly for cable, movies and rare gaming. the kids are growing to gaming may be improtatnt in next 5 years.
need recs for 5.1 surround sound system with a minimalist look? Budget around 3500$
like the look of wall mount and satellite speakers. would lik eto stay away from tower..
considering
psb imagine on wall (60 and 25 for surround)
monitor audio shadow
paradigm millenia hybrid 20
golden ear supersats (50 and 3 for surrounds)
revel M10, c10 and s12's
will it be bad (for sound quality) to have 2 wall mounted speakers on either sider of the screen and the center in the bottom. i can mount the L/R to match the bottom of the screen
thanks in anticipation
Gary
gbandi is offline
post #2 of 2 Old 01-18-2013, 01:10 PM
UGAd13's Avatar
Quoted: 100 Post(s)
Liked: 121
Originally Posted by gbandi View Post
will it be bad (for sound quality) to have 2 wall mounted speakers on either side of the screen and the center in the bottom. i can mount the L/R to match the bottom of the screen
No - if you can pivot/angle the center to aim the sound at your head you're good to go.
My living room budget build: Samsung PN51E530 / Denon AVR1613 / DefTech PC1000 / DefTech PM60 / DefTech ProSub 60 / Dayton Sub1200
UGAd13 is offline
Reply Speakers
