First speaker build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-19-2013, 05:59 PM - Thread Starter
cbo0485's Avatar
Building a home theater in my basement in a month or so. Already got the projector, screen, chairs, and receiver picked out. I need some help with the speakers though.
I'm getting a Panasonic ae7000, a screen from Jamestown screens, and a Sony STR-DN1030 receiver.
I like the Sony because its got the built in wifi, Bluetooth, and it gives me the flexibility to go to 7.2 if I want.
I'd like to spend around 750-1000 for the 5 speakers and a sub. I'd like the front two to be floor standing, but its not a requirement. Te only real requirement is that when I watch a movie, you get that movie theater experience. Sound and all.
I was able to do quite a bit of research on the projectors, but having a hard time finding good info on the speakers.
Sent from my iPad using Tapatalk HD
cbo0485 is offline
post #2 of 12 Old 01-19-2013, 06:01 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Is your screen acoustically transparent?
Jay1 is offline
post #3 of 12 Old 01-19-2013, 06:13 PM - Thread Starter
cbo0485's Avatar
No, speakers aren't behind the screen. They will be in front(center either on the ground or mounted right above) and the two fronts will be on either side of the screen.
Sent from my iPhone 5 using Tapatalk
cbo0485 is offline
post #4 of 12 Old 01-19-2013, 06:19 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
If this is a dedicated theater you should consider doing it right, meaning vertically positioned speakers behind an acoustically transparent screen. You havent bought anything yet right?
Jay1 is offline
post #5 of 12 Old 01-19-2013, 06:27 PM - Thread Starter
cbo0485's Avatar
Well now that you got me researching that stuff again, I may try to get an AT screen and place the center speaker behind the screen. I'd have to cut open the wall and mount the center channel in there.
Lets assume both, does it make a difference if I get an AT screen and place the center channel behind the screen, or if I put the speaker above or below. I know it makes a difference, but does that make a difference in which speaker i should buy?
Right, haven't bought anything yet.
cbo0485 is offline
post #6 of 12 Old 01-19-2013, 06:36 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Ideally you would have 3 identical speakers positioned equally behind the screen, like this
Nothing wrong with using in walls for a setup like yours
Jay1 is offline
post #7 of 12 Old 01-19-2013, 06:40 PM - Thread Starter
cbo0485's Avatar
so instead of buying a center speaker, buy three of the front speakers and just hook them up correctly. Then place them behind the screen like in your picture. I assume I would place one dead center, and then the two sides equa-distance from the edge of the screen?
cbo0485 is offline
post #8 of 12 Old 01-19-2013, 06:42 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Jay1 is offline
post #9 of 12 Old 01-19-2013, 06:49 PM - Thread Starter
cbo0485's Avatar
Okay, thanks for the advice. Now, anyone wanna recommend three of those types of speakers for around 175-200ish. Then a couple rears for and a sub for 3-400 or so?
Total just needs to be around 1000 or so.
cbo0485 is offline
post #10 of 12 Old 01-20-2013, 09:31 AM - Thread Starter
cbo0485's Avatar
Now since this is going t be a dedicated home theater( on a budget unfortunately), are speakers built specifically as in wall speakers any less powerful and quality than their floor standing counter parts?
I was looking at the following speakers.
http://www.crutchfield.com/p_107RC85I/Polk-Audio-RC85i.html
http://www.crutchfield.com/p_714R2502W/Klipsch-R-2502-W.html
http://www.crutchfield.com/p_10765RT/Polk-Audio-65-RT.html
Of those would three of those be good for a home theater? Would they generate enough power? Or should I be looking at buying 3 floor standing speakers and custom mounting those?
cbo0485 is offline
post #11 of 12 Old 01-20-2013, 12:05 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Due to the infinite baffle nature of wall placement, an in-wall version of a standmount speaker will be more powerful. There does seem to be a lot of low quality products in this price range, ideally you would have a speaker with an enclosed back. Out of the 3 you listed the Polk 65-RT looks like the best one.
Jay1 is offline
post #12 of 12 Old 01-20-2013, 12:35 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
I think these Bic FH8-W's are going to be the best bet for your price range
http://www.amazon.com/BIC-America-FH8-W-175-Watt-Frequency/dp/B000WS0M4Y
Very dynamic speakers. Yes you would have to buy 2 pairs to get the 3 speakers, that just means you'll have a backup speaker. These would be your surrounds
http://www.parts-express.com/pe/showdetl.cfm?partnumber=303-444
That leaves you $300-500 for a sub. This Klipsch would be a good buy for the low end of your budget
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780078
I'm a fan of dual subs, a pair of these very nice JBL's are still under budget
http://www.newegg.com/Product/Product.aspx?Item=N82E16882665157
Jay1 is offline
Reply Speakers
