Budget bookshelf speaker recommendations - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 01-19-2013, 07:21 PM - Thread Starter
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
I'm looking for 3 new bookshelf speakers for my fronts. I'd like to spend about $250 max. for all 3, if possible. They will sit on a 1X10 shelf behind TV, so I want front ported or sealed speakers. Use is about 70% movies, 30% music. I'm interested in the following speakers.
Infinity - Primus P163
Are there others within my budget you recommend?
Jim McC is offline
post #2 of 15 Old 01-19-2013, 07:47 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3097
Both are great budget speakers. The Pioneer BS22 and C22 are within your $250 budget. The Primus 163s are in fact front-ported but the matching channel PC251 or PC351 will put you over budget. Using another 163 as the center would also put you over budget.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is online now
post #3 of 15 Old 01-19-2013, 08:15 PM - Thread Starter
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
Thanks. I just read the P163's are 11" deep, which means I would have to put up a deeper shelf. I'd rather not do that. And the Pioneers are rear ported, which means I couldn't flush mount them for surrounds, like my current surrounds are. Any other recommendations?
Jim McC is offline
post #4 of 15 Old 01-19-2013, 08:26 PM
zieglj01's Avatar
Quoted: 940 Post(s)
Liked: 846
Should be going on sale around January 24
HTD Level Two
http://www.htd.com/Products/level-two-speakers
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #5 of 15 Old 01-19-2013, 08:30 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3097
The Cambridge S30s have the right dimensions. They are rear-ported but 3 in. behind might be sufficient. They are $219 however. The matching center is the S50 at $199. On the same token, a few inches behind the BS22s might suffice as well. In any case, all of these speakers would sound best on stands but you are probably well aware of this.
post #6 of 15 Old 01-19-2013, 09:22 PM - Thread Starter
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
Thanks guys. Any other recommendations for front ported or sealed bookshelf speakers? Thanks.
Jim McC is offline
post #7 of 15 Old 01-20-2013, 03:16 AM
dowop's Avatar
Quoted: 42 Post(s)
dowop is offline
post #8 of 15 Old 01-20-2013, 03:43 AM
ScaryFatKidGT's Avatar
Pioneer SP-BS51-LR ($130 on amazon) and the center
The new ones only make 4" book shelves (the SP-BS42) where the older style cam in a 5.25".
ScaryFatKidGT is offline
post #9 of 15 Old 01-20-2013, 10:28 AM
afrogt's Avatar
Quoted: 1056 Post(s)
Liked: 757
To my knowledge there is no BS42 speaker only a BS22 which has the 4" woofer.
And I also think you mean BS41 bookshelf since the only Pioneeer xS51 is the FS51 tower. No BS51 exists.
Afro GT
afrogt is offline
post #10 of 15 Old 01-20-2013, 11:45 AM
zieglj01's Avatar
Quoted: 940 Post(s)
Liked: 846
I do not tink that there will be a rush to make a BS42 - The BS22 bookshelf has a lower
-3 db bass point over the BS41 bookshelf. >>> The BS22 can play loud and take some
power and will not easily burp. That is a good woofer on that speaker.
Who AM I
zieglj01 is offline
post #11 of 15 Old 01-20-2013, 02:47 PM - Thread Starter
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
There is no such speaker on Amazon or Pioneer's website. And the BS series are rear ported anyway.
Jim McC is offline
post #12 of 15 Old 01-20-2013, 02:53 PM - Thread Starter
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
Thanks, but those are rear ported. I need front ported or sealed.
So far, the Infinity P163 it is.
To review, I need 3 bookshelf speakers for about $250, front ported or sealed.
Jim McC is offline
post #13 of 15 Old 01-20-2013, 03:42 PM
feedthemachine's Avatar
http://www.amazon.com/RE-16-Bookshelf-Theater-Satellite-Speakers/dp/B0037BPCHU/ref=cm_cr_pr_product_top
I don't own these nor ever heard them ,,but i love CV and have always had them
feedthemachine is offline
post #14 of 15 Old 01-21-2013, 02:49 AM
Yeah I meant BS21/22 and 41 (I was thinking 5 for 5 inch 4 for 4 inch).
post #15 of 15 Old 01-21-2013, 11:21 AM - Thread Starter
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
Thanks. The BS22's were my first choice, until I found out they are rear ported. Anyway, I ordered the Infinity P163's last night.
Jim McC is offline
Reply Speakers
