SP-BS22-LR Mounting - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 01-19-2013, 09:28 PM - Thread Starter
xkaijinx's Avatar
Quick question, there is no screw on the back of these for mounting. There are nice sized holes in the back of these speakers, are these for mounting? Would the below part work out for this?
I was trying to avoid purchasing the mounting with the flat base that the speakers would sit on.
http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=240-828&scqty=1
xkaijinx is offline
post #2 of 14 Old 01-19-2013, 10:10 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Those Pioneer speakers are over 9lbs each and 12.5" tall. Max on that mount is 8lbs and I wouldn't trust that much. You need something sturdier than that.
with their curved cabinet these speakers really weren't made to be wall mounted.
What are the holes like on the back. Do you have pics?.
Afro GT
afrogt is offline
post #3 of 14 Old 01-20-2013, 01:48 PM - Thread Starter
xkaijinx's Avatar
Ok, I took a picture of the back. Please let me know! Thanks. IMG_0051.JPG 793k .JPG file
xkaijinx is offline
post #4 of 14 Old 01-20-2013, 02:33 PM
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
Those speakers cannot be wall mounted because of the rear port(that's the large open hole). That's also why there are no mounting screw holes on them. I was also considering these until I found this out.
Jim McC is offline
post #5 of 14 Old 01-20-2013, 04:29 PM - Thread Starter
xkaijinx's Avatar
Ah damn. I was not sure what that was called or if it was for a special mounting bracket! -.-
I will buy a flat speaker stand than and use velcro on the bottom to hold it in place. Thanks
xkaijinx is offline
post #6 of 14 Old 01-20-2013, 04:35 PM - Thread Starter
xkaijinx's Avatar
It looks like this would work the best for wall mounting.
http://www.amazon.com/gp/product/B000X9O8SI/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=A1YX7EB80E4EIU
tdogroeder likes this.
xkaijinx is offline
post #7 of 14 Old 01-20-2013, 04:39 PM
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
Either that, or just use a small shelf.
Jim McC is offline
post #8 of 14 Old 03-25-2014, 01:36 PM
Sacc Attack's Avatar
Quoted: 13 Post(s)
bump for more options or stand recommendations
Vizio m55
Yamaha v475
Pioneer Andrew Jones 5.0, BIC F12
PS4, AppleTV, DirecTV
Sacc Attack is offline
post #9 of 14 Old 03-25-2014, 03:25 PM
tdogroeder's Avatar
Quoted: 41 Post(s)
Liked: 81
Those in the link above are probably going to be your best option for mounting.
John 14:6 & John 3:16
Yamaha RXV765 & Emotiva LPA-1
Ascend Sierra-2s(LCR), RSS300, Polk R15, SVS PB12 plus
Panasonic S65, Sony S5100, PS4, PS3, XBOX 360
tdogroeder is offline
post #10 of 14 Old 03-27-2014, 11:08 AM
Quoted: 13 Post(s)
bought the mounts linked above. thanks. will report back on how they work out. Was hoping to avoid drilling holes to help the house sell easier someday but I think it's unavoidable. Going to build a shelf for the front channel too.
Vizio m55
Yamaha v475
post #11 of 14 Old 08-18-2014, 08:14 PM
Liked: 7
You'll want to avoid wall-mounting because these speakers are rear-ported.
Samsung PN60F5300 TV | Antec bias lighting | Energy RC-Micro 5.1 speaker system | Yamaha RX-V375 receiver | Xbox One with Kinect 2.0 | Aura AST-2B-4 Pro bass shakers | Logitech Harmony 650 remote
.SKITTLE. is offline
post #12 of 14 Old 09-04-2014, 09:10 AM
spencerdav's Avatar
Liked: 0
wall mount
How did these wall mounts work out for you? Also, why does the rear port effect wall mounting?
spencerdav is offline
post #13 of 14 Old 09-04-2014, 10:05 AM
SyntheticShrimp's Avatar
Quoted: 241 Post(s)
Liked: 210
Front ported or rear ported makes quite little difference. In either case, a speaker designed for free space operation, such as the Pioneer bs-22, will probably give you better results if you stuff the port when wall-mounting.
SyntheticShrimp is offline
post #14 of 14 Old 04-26-2015, 01:20 PM
-Jim-'s Avatar
Quoted: 74 Post(s)
Liked: 24
Gents,
I wish I had seen this Thread before I mounted my SP-BS22-LRs in my home office a couple of weeks back. Because my JBL Loft30s are rear ported and come with a simple wall bracket (so do their Loft40s) on the back to slip a screw into, I thought these would be fine that way. So I borrowed some small brackets off an old set of speakers and screwed them in. There was no caution about wall mounting in the manual.
I suppose they would sound better if the port were in free air.
Jim
-Jim- is offline
Reply Speakers
Pioneer Andrew Jones Designed Bookshelf Loudspeakers Sp Bs22 Lr
