Center channel speaker OR 3 identical front speakers ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-20-2013, 02:24 AM - Thread Starter
Jim McC's Avatar
Quoted: 116 Post(s)
Liked: 58
I'm considering the Infinity Primus P163's for my front speakers. But the center channel speaker is more than double the price. There's no problem if I use 3 of the P163's for the fronts, and skip the center channel speaker, is there? That is supposedly ideal, isn't it? All 3 speakers will be at the same height, sitting on a shelf. Usage is 70% movies and 30% music. Thanks.
Jim McC is online now
post #2 of 3 Old 01-20-2013, 02:39 AM
afrogt's Avatar
Quoted: 1062 Post(s)
Liked: 768
It's ideal if you can use 3 of the same speaker across the front stage. Will the P163 be upright for the center channel?
Afro GT
afrogt is online now
post #3 of 3 Old 01-20-2013, 03:00 PM - Thread Starter
Jim McC's Avatar
Quoted: 116 Post(s)
Liked: 58
Yes. It needs to be upright, correct?
Does anyone have any recommendations for nice bookshelf speakers comparable, or better than the Infinity P163's? They need to be front ported or sealed. Budget is $250 or less for 3. Thanks.
Reply Speakers
