Wharfedale DFS vs 10.sr - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-20-2013, 03:40 AM - Thread Starter
ScaryFatKidGT's Avatar
Little book shelf surround or bi-pole?
Then for a 7.1 are the right and lefts usually di/bi-pole's if the rears are or are they bookshelfs?
ScaryFatKidGT is offline
post #2 of 4 Old 01-25-2013, 06:25 PM - Thread Starter
post #3 of 4 Old 01-26-2013, 08:13 AM
CDLehner's Avatar
Quoted: 767 Post(s)
Liked: 1146
There is no "usually"; everyone is different, and it's mostly a matter of preference/design, etc. That being said...I like di/bi on the sides (surrounds) and direct-radiating in the rear; but again...everyone is different. Good luck.
ScaryFatKidGT likes this.
CDLehner is offline
post #4 of 4 Old 01-26-2013, 08:17 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
The ROOM and the location determines whether dipolar speakers will work well.
I usually advise against them because they just won't work well in many situations.
It is much easier to make the system work well with regular bookshelf speakers.
commsysman is offline
Reply Speakers
