Need some advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-21-2013, 09:26 PM - Thread Starter
jayk101's Avatar
Ok folks need some advice here. I'm trying to get my first home system goin but not sure what speakers to go with. So far I have an Energy 10 center and my wife just got me the Denon 2112 receiver. My fronts right now are some Bose 301's that I really need to lose, just not sure what to replace them with or what kind i should get for rears. The way my room is set up i want to put the rears in the back corners by ceiling, but dont want anything to clunky lookin. And i was thinkin about the Energy 10 sub. I have 1000 bucks right now but i figured on gettin a bit at a time. Any help is appreciated. eek.gif
jayk101 is offline
post #2 of 7 Old 01-22-2013, 07:49 AM
Elihawk's Avatar
Quoted: 1014 Post(s)
Liked: 856
Well, the L/R speakers that match the Energy 10 center (CB10 speakers?) would be the first step, and then maybe a subwoofer, and surrounds last?!
Why did you buy the Energy 10 center channel by itself? I assume it was because you wanted all Energy up front...
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
post #3 of 7 Old 01-23-2013, 12:49 AM - Thread Starter
jayk101's Avatar
I picked up the center because my 301's just weren't cuttin it anymore and the energy sounded pretty nice. Due to my budget i cant drop alot of cash at once so im buying bit by bit so i can get a decent system.
jayk101 is offline
post #4 of 7 Old 01-23-2013, 01:03 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Pick up a pair of CF30's, we'll say $400 shipped.
http://www.amazon.com/Energy-CF-30-Floorstanding-Tower-Speaker/dp/B001SAJ1VA
The Energy subs arent anything special, and you dont have to match subs by brand. I would check out this svs for $500
http://www.svsound.com/subwoofers/ported-box/pb-1000#.UP-ZhGc1X-V
You can then move your bose speakers to surround duty, or you can pick up this Boston Soundware's, which work very well mounted in corners
https://www.accessories4less.com/?page=deal_of_the_day
Jay1 is offline
post #5 of 7 Old 01-23-2013, 04:10 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
You can get a pair of Monitor Audio BX-5 speakers for $750.
They will sound way way better than some of the other speakers mentioned so far IMO.
Or, if you don't want floorstanding speakers, the BX-2 is less than $500 per pair, and also very good.
The Energy 10 sub is pretty wimpy; not enough for most rooms.
The Polk PSW505 is only around $200, and it is a REAL subwoofer; 12-inch driver and enough power to actually woof instead of just puffing like the little puppies.
commsysman is offline
post #6 of 7 Old 01-23-2013, 08:36 AM
Elihawk's Avatar
Liked: 856
When you buy a center channel speaker, you really are defining your front stage to that brand and model...unless you don't mind a timbre mismatch in the front!
Elihawk is offline
post #7 of 7 Old 01-28-2013, 11:09 PM - Thread Starter
jayk101's Avatar
I actually like the look of towers up front o ill probably go with them but what do u mean by timbre mismatch if i get different brand. I assumed different brands wouldnt be a big deal
jayk101 is offline
Reply Speakers
