3.1 Home Theater advice $1500-2k budget - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-23-2013, 07:18 AM - Thread Starter
moogs's Avatar
My living room is about 15' x 15' with a ceiling that is open for the second floor. There are hardwood floors everywhere but I might be putting down a rug.
I need a receiver, and speakers for a 3.1 setup with a budget of around $1500-2k. Spending less is better obviously. I honestly don't know where to start since this is my first time buying this kind of equipment.
moogs is offline
post #2 of 9 Old 01-23-2013, 01:18 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1352
I think you will need a good subwoofer, its sounds like your living room has considerable spatial volume. The problem with bass is it has to pressurize the whole open area if you are to get a good response throughout, especially if your listening position is in the middle of the room rather than against the walls. It you are seated next to the wall, you won't need a monster subwoofer (although its a lot of fun to have one anyway).
Here is one setup I can recommend that I think most people would be pleased with:
2 x Infinity Primus p363 tower speakers for fronts, $400
Infinity Primus c351 center speaker, $200
Hsu VTF3 mk4 subwoofer, $800
Onkyo TX-SR717 receiver, $600
There is a killer setup for $2k shipped, lots of punch and dynamic range.
If you want to save some money, another good setup would be the Hsu Hybrid 2 3.1 package and Denon AVR1713, that would only be $1600 shipped.
shadyJ is offline
post #3 of 9 Old 01-23-2013, 09:14 PM
RPGMasta's Avatar
Quoted: 18 Post(s)
i got the Infnity Primus 363s at Fry's for $117 each. I've read around these forums they can be as low as $99 each. Many times I will grab for the remote to try to reduce the sub level, but it's not even on! i like them alot.
The C351 center is on sale at amazon.com right now for $199, but on backorder.
Sometimes our circuits get shorted by external interference,
Signals get crossed and the balance distorted by internal incoherence.
RPGMasta is offline
post #4 of 9 Old 01-23-2013, 11:19 PM
shadyJ's Avatar
Liked: 1352
The c351 are in stock at crutchfield's, the one I linked to.
shadyJ is offline
post #6 of 9 Old 01-24-2013, 03:22 AM
smasher50's Avatar
Quoted: 379 Post(s)
Liked: 19205
+1 pretty solid choices for the money or can save a few bucks on a single sub svs-pb12-nsd $769
if you dont care for the white a360's(imo look good with black grills)
take a look at the ascend acoustic cmt340se's and matching center $904
the denon avr 1912 $350
svs pb12-nsd $769
i'm so laid back,i'm laid out
smasher50 is offline
post #7 of 9 Old 01-24-2013, 07:39 AM
ousooner2's Avatar
Quoted: 291 Post(s)
Liked: 179
Denon 1712 - $310
EMP e55ti and e56ci - $1,250
HTD Level 3 Towers/Center - $1,000
Focal 814v & cc814v - $1,150
Arx a5 & a2 center - $1,000
Leaves roughly $500-700 for sub to reach your $2,000 budget. That's plenty of sub for that size room. Plenty of choices in that budget also.
Currently Auditioning: Klipsch RP-150M
SOLD: EMP e55ti / EMP e56ci / EMP e5bi / (2) e1010i
FOR SALE --- 1 EMP Tek/RBH Sound e1010i sub: http://www.avsforum.com/forum/209-au...al-10-sub.html
ousooner2 is offline
post #8 of 9 Old 01-24-2013, 11:35 AM - Thread Starter
moogs's Avatar
Oh wow, thanks guys. Any recommendations on rear speakers in case I wanted to go 5.1? I really don't like the idea of running wires around and that's why I was thinking 3.1.
moogs is offline
Reply Speakers
