Center speaker for Pioneer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-24-2013, 08:38 PM - Thread Starter
burnet77's Avatar
I need to find a center channel speaker to go with my Pioneer Andrew Jones SP-FS52-lrs. The center channel speaker that goes with theses is an inch or two too tall for my current setup. Is there something out there that will work with this setup, and that is 6" or less in height?
burnet77 is offline
post #2 of 3 Old 01-24-2013, 09:06 PM
GaryWA's Avatar
Quoted: 16 Post(s)
You really want to go with that Pioneer center. It is from the same series and that's what you want. You could get close with something else, but the only thing that perfectly matches your fronts is going to be the Pioneer center.
GaryWA is offline
post #3 of 3 Old 01-24-2013, 09:14 PM
Kingpin32's Avatar
I was in the sane boat in regards to the center channel. I was looking for something a bit more low profile but went with ever ones advice and kept the pioneer center. Ended up having to mount my TV a few inches higher than I expected. Glad I did. System sounds great.
Sent from my SGH-I777 using Tapatalk 2
Kingpin32 is offline
Reply Speakers
