My new setup - AVS Forum | Home Theater Discussions And Reviews
Old 01-25-2013, 10:29 AM - Thread Starter
jowens's Avatar
I am finishing up my theater room and am going with martin logan motion 12's up front with a motion C center. I was thinking about motion 4's for the back and am using a klipsch 12d for the sub. I am also planning on running the pioneer sc-1222 as the receiver. I really want to add a couple more speakers to finish out the 7.1 but what should I go with? I really don't want to spend another $500 for a couple more motion 4's. Anybody have any other ideas or suggestions? I am not opposed to throwing a couple in the ceiling, I just need to figure it all out before I wire and close it all up.
jowens is offline
Old 01-26-2013, 01:35 PM - Thread Starter
jowens's Avatar
Anyone?
jowens is offline
Old 01-28-2013, 08:08 AM - Thread Starter
jowens's Avatar
Ok, what about a set of Motion 10 floor standing speakers for the rear? They are down to $170 each and would someone recommend these over the motion 4's? I wasn't really thinking about and in-wall speakers but Audio Advisor has some pretty good deals on martin logan passage and ticket in-wall speakers. I'm just looking for some recommendations from anyone else here that has a martin logan system
jowens is offline
Old 01-28-2013, 06:52 PM - Thread Starter
jowens's Avatar
Bump for at least one persons help
jowens is offline
Old 01-28-2013, 07:27 PM
highdefav1's Avatar
Quoted: 106 Post(s)
Liked: 37
Not sure about the floor standing speakers for rears. What about the Motion 2's for the surrounds and surround backs if you want to save some money. Otherwise, I would just go for the 4's for both surrounds and surround backs.
Let me ask, why ML's? Have you looked at other manufacturers?
Panasonic 55ST50
Yamaha RX-V673
Klipsch RF-52 II // RC-52 II // RS-42 II
Klipsch RW-12d
Klipsch KG 2.5
highdefav1 is offline
