Front Speakers with YAMAHA RX-V471 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-25-2013, 11:33 AM - Thread Starter
JimiC's Avatar
I´ve got a receiver YAMAHA RX-V471, and i´m looking for 2 front speakers, they will be the only ones by now.
My intention is to listen to music (rock, jazz, blues) and watch movies 50% 50%, small living room, about 16m2.
My idea is to find two "ok" front speakers for a low/medium price, later i will add the rest for the HT.
In a price range i made a "small" list, what do you guys think?
Others suggestions would be welcome.
JBL ES20 High-Performance 3-Way Bookshelf Speakers
Polk Audio RTI A1 Bookshelf Speakers
Polk Audio TSi200 Bookshelf Speakers
Polk Audio RTi4 High Performance Bookshelf
Polk Audio Monitor 45B 2-Way Bookshelf Speakers
Energy CB-5 Bookshelf Speakers
Infinity Primus P163BK Two-way 6 1/2-Inch Bookshelf
Pioneer SP-FS52-LR Andrew Jones Designed Floor standing Loudspeakers
Pioneer SP-BS21-LR 80 Watt RMS 2-Way Speakers
SONY SSB3000 Performance Bookshelf Speakers
SONY SS-F5000 Floor-Standing Speakers
Boston Acoustics CS23IIB 2-Way 3-1/2 " Bookshelf Speaker
Definitive Technology StudioMonitor 350 Bookshelf
Jamo S426 Floorstanding Speaker * 6 Ohms
* Jamo is 6 Ohms, does that do any difference?
** I noticed in some speaker's description the word "Crossover", but not in others, is that relevant?
Thank you very much!
JimiC is offline
post #2 of 7 Old 01-25-2013, 11:39 AM
commsysman's Avatar
Quoted: 971 Post(s)
Liked: 523
For $200, Amazon still has a few pairs of Monitor 40 speakers for $200 per pair.
You can also get the Polk R300 tower speakers for $90 each.
Either of these would be the best sound for the buck in that price bracket IMO.
For front speakers, you want the main driver to be at least 5.5 inches; no smaller.
commsysman is offline
post #3 of 7 Old 01-25-2013, 11:45 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
I have the Polk RTi4's as my front two speakers and I love them however I have found they need along with other bookshelf speakers need a subwoofer to really shine. Yes I am amazed with the RTi4's performance alone without a subwoofer but it really helps to have one
I would look at the Pioneer towers since they would perform the best until you get a subwoofer
crazyrob425 is offline
post #4 of 7 Old 01-25-2013, 11:58 AM - Thread Starter
JimiC's Avatar
Thanks for the opinions guys.
Yes rob, i just don´t know if bookshelves are good enought without a subwoofer, if i should get a tower... But problably it depends on the quality, not the type, right?
JimiC is offline
post #5 of 7 Old 01-25-2013, 12:01 PM
GaryWA's Avatar
Quoted: 16 Post(s)
The Andrew Jone's Pioneer speakers are highly underrated. I recommend those with your setup.
GaryWA is offline
post #6 of 7 Old 01-25-2013, 12:15 PM - Thread Starter
JimiC's Avatar
Votes: hahaha
Polk Audio AM4095-A Monitor40 Series II
Polk R300 tower
* I´m not thinking in a subwoofer right now...
JimiC is offline
post #7 of 7 Old 01-25-2013, 04:50 PM - Thread Starter
JimiC's Avatar
Any one else?
JimiC is offline
Reply Speakers
Yamaha Rx V471bl 5 1 Channel Av Receiver
