which should I get first, sub or center? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 01-25-2013, 01:15 PM - Thread Starter
DanPopov's Avatar
I have a Yamaha RX-V473 receiver and a pair of Polk RTi8's. I know I want to get both a sub and a center, but I'm just wondering what people think would be better to get before the other. If it helps any, as far as subs go I'm looking at either Polk PSW505 $190 at Newegg or a mfr refurb Polk DSW pro 440WI for $243. The center I'm considering is mfr refurb CSi5 for $225. Thanks a lot!
DanPopov is offline
post #2 of 14 Old 01-25-2013, 01:31 PM
GaryWA's Avatar
Quoted: 16 Post(s)
Sub.
Here's a Klipsch RW-12d for $300 w/ code. EMCXWVS87
GaryWA is offline
post #3 of 14 Old 01-25-2013, 01:32 PM
rich7sena's Avatar
I think it depends on your preferences and situation.
I think a 3.0 is a better build for a home theater setup (movies) and a 2.1 is better for listening (music). I opted to go with a 3.0 because I am more than satisfied with the bass I'm getting out of my TSi300 for now (especially when calibrated). I imagine the RTi8's would do even better in that regard.
DanPopov likes this.
rich7sena is offline
post #4 of 14 Old 01-25-2013, 01:41 PM
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1038
I would always say sub before center, but if these are the subs you are looking at, I would add the center and save for a good ID sub or dual subs.
Reefdvr27 is offline
post #5 of 14 Old 01-25-2013, 02:26 PM - Thread Starter
DanPopov's Avatar
Clearly you're not a fan of the subs I'm considering...What is it about them that you don't like?
DanPopov is offline
post #6 of 14 Old 01-25-2013, 02:59 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
The Polk PSW 505 isn't a bad sub per se. But if you want a real performer then ID subs are going to give you much more value for your money. As far as the rest of Polk subs go, they're not very good.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #7 of 14 Old 01-25-2013, 03:01 PM
Bill Fitzmaurice's Avatar
Liked: 4667
Originally Posted by DanPopov View Post
I have..a pair of Polk RTi8's. I know I want to get both a sub and a center, but I'm just wondering what people think would be better to get before the other.
That depends on where you think the system shortcomings are. With your floorstanders a sub won't go so much lower to make much difference other than in output. If you can't get the low end output you want do subs first, two twelves. One twelve won't make a huge difference compared to four sixes, and you can't smooth room modes with one sub. Otherwise get a center first,
Bill Fitzmaurice is online now
post #8 of 14 Old 01-25-2013, 03:14 PM
Bond 007's Avatar
Quoted: 2375 Post(s)
Liked: 1911
+1 on Yoda. Get a center unless you're willing to spend enough to get a much more expensive sub than what you are looking at or 2 nice ones. Either way you're talking somewhere in the $600-$1000 range.
Licence to Kill
Bond 007 is offline
post #9 of 14 Old 01-25-2013, 03:47 PM - Thread Starter
DanPopov's Avatar
Originally Posted by Bill Fitzmaurice View Post
With your floorstanders a sub won't go so much lower to make much difference other than in output. ,
Thanks, I was leaning toward the center 1st for that very reason. So no complaints about the CSi5 center to go with my RTi8's?
DanPopov is offline
post #10 of 14 Old 01-25-2013, 05:57 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
I'm not a fan either. You are looking at budget subs when your speakers are a higher class. Wait until you can get a good 12" ID sub.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #11 of 14 Old 01-25-2013, 07:23 PM - Thread Starter
DanPopov's Avatar
What makes them bad compared to the ones you think are good? Since the big boxes don't carry any of that, it's frustrating that there is no way to hear them so an explanation would be really helpful, thanks!
DanPopov is offline
post #12 of 14 Old 01-25-2013, 07:30 PM
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 36
Well...you can go Phantom center... But if you get decent tower fronts ...Sub is not absolutely required ..right away. We are all assuming HT purposes I think.
You will want your center to match your front stage speakers...front left and right... So its normally best to buy all 3 at once. Tough call.
I think the deciding factor is your front sound stage floor standers or not...if not then go with sub.
Newbie01 is offline
post #13 of 14 Old 01-25-2013, 07:53 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Center first than save up at least $400 for a subwoofer.
the CSi5 is the matching center for the RTi8's
I have the RTi4's and CSi3 center and it sounds perfectly!
crazyrob425 is offline
post #14 of 14 Old 01-25-2013, 08:29 PM
Liked: 4667
It's probably no worse than most horizontal centers, but it is flawed. The midbass drivers should be spaced as tightly as possible. Horizontally placed drivers will have comb filtering at the upper end of their bandwidth, with narrowed dispersion at the lower end, and the wider they're spaced the worse it is.
Reply Speakers
