Budget near field speaker set-up? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 01-25-2013, 03:03 PM - Thread Starter
gopanthersgo1's Avatar
Hey all, I'm selling my Sennheiser HD650s, and am looking to get a decent 2 channel set up (For my PC). These will be mainly for Anime, movies, and games. I already have a nice 2 channel digital to analog converter. I don't really have a budget, but it needs to be cheap (At the VERY most, $150 for the speakers, as long as each upgrade gives it a (much) better sound). I will purchase a subwoofer later once I get the funds. Active or passive, I don't care, I'll buy an amp for the passive (~$50).
Mark K.
gopanthersgo1 is offline
post #2 of 27 Old 01-25-2013, 03:30 PM
BobL's Avatar
Liked: 56
Samson mediaone 4a, M-audio AV-40 both sell for $150 a pair but can be found for less.
BobL is offline
post #3 of 27 Old 01-25-2013, 03:54 PM - Thread Starter
How do those compare to the Pioneer SP-BS22-LR?
post #4 of 27 Old 01-25-2013, 05:25 PM
ScaryFatKidGT's Avatar
Problem with them is needing an amp and $50 for an amp isn't much, I have some monitors and the BS41's but not the AV40's. I'm going to guess that the BS42's will be more detailed but that the monitors will have more treble and bass extension and be a little more balanced.
I second the AV40's or theres the KRK rokit 5's and the Audioengines
ScaryFatKidGT is offline
post #5 of 27 Old 01-26-2013, 12:16 AM - Thread Starter
Hmm... I'm fine picking up a more expensive amp for sure... So how is the AV40 sound signature? I want a "crisper" sound, but not prone to sibilance or too treble happy...
post #6 of 27 Old 01-26-2013, 03:22 PM - Thread Starter
BUMP
post #7 of 27 Old 01-26-2013, 03:36 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3080
The AV40s have a tendency to get really hot. They have decent SQ though. I think the BS22 would be a better option. If you could scrape together a little more money the Cambridge S30s would be excellent ($219). The Cambridge S20 is in your price range though ($149).
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #8 of 27 Old 01-26-2013, 03:38 PM - Thread Starter
How much of a difference would the S30s make?
post #9 of 27 Old 01-26-2013, 05:14 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3080
IMHO, they would make a big difference. They're probably the best speaker in this price range. It's truly quite remarkable how good these sound given the $219 price tag. I can think of a number of powered speakers that might make more sense for your situation but they're priced well outside of your budget (Audioengine, Swans, Emotiva Airmotivs for example).
post #10 of 27 Old 01-26-2013, 05:30 PM - Thread Starter
Hmm... I've seen those recommended a lot, I'll have to think about it some, but I think I might get them. Any recommendations on a cheap amp for them (IE: Lepai 2020+)? I'll most likely purchase a better amp for them later, but that'll be after I get some decent headphones... (IE: Mad Dogs, or mod some TH50Ps)
post #11 of 27 Old 01-26-2013, 06:09 PM
cyde01's Avatar
Splurge a little and get the Cambridge S30s. They sound so much better than their price would indicate. Plus they'll last you over 10 years, so what's an extra $100 for years of enjoyment?
If you have a spare 19v laptop charger lying around, I'd pick up a 50wpc Sure board amp off Ebay for $25 shipped. No gain attenutator, but that doesn't matter since you're using it to power PC speakers. You could control volume through your desktop. Otherwise you could get a 15wpc board and attach it to a 12V rail on your computer's power supply. It's small enough to fit inside your case too.
50w
http://www.ebay.com/itm/2-X-50-Watt-6-Ohm-Class-D-Audio-Amplifier-Board-TDA7492-/110946490563?pt=US_Home_Audio_Amplifiers_Preamps&hash=item19d4ed18c3
15w
http://www.ebay.com/itm/2-15-watt-4ohm-TA2024-D-class-Audio-Amplifier-Board-/350594264358?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D27%26meid%3D5159034050771990780%26pid%3D100033%26prg%3D1011%26rk%3D4%26sd%3D270683548580%26
I used the 15w board in my rig for a while, and it worked well. I replaced it with a Marantz receiver I stored off Ebay for practically free, but the board amp is still going strong in my garage set up. They're great for their price as is but really shine after some simple mods.
cyde01 is offline
post #12 of 27 Old 01-26-2013, 10:00 PM - Thread Starter
I think I'll have to go with the Pioneers... I need the other money for a monitor, headphones, and an amp/DAC. Would the 50W/CH still be good for the Pioneers, or would the 2020+ be better?
post #13 of 27 Old 01-26-2013, 10:14 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3080
50W/channel should be fine.
post #14 of 27 Old 01-26-2013, 10:47 PM - Thread Starter
Ok, thanks!
post #15 of 27 Old 02-02-2013, 03:29 PM - Thread Starter
50w
15w
Would the 50 W/Ch work with a power prick with an output of 19V, 1.58A, and 30W? Also, what mods are there?
post #16 of 27 Old 02-03-2013, 01:15 PM - Thread Starter
Okay... ordered the 50W/Ch amp and the Pioneers! biggrin.gif
post #17 of 27 Old 02-04-2013, 10:37 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3080
post #18 of 27 Old 02-05-2013, 09:11 PM - Thread Starter
Thanks! Speakers are in tomorrow, and I don't know when the amp is though... frown.gif I think I'll use an old reciever for the week or two... wink.gif
post #19 of 27 Old 02-19-2013, 03:56 PM - Thread Starter
They have been sounding GREAT (With the receiver)! Just got my amp, and am making a case using the box... (Ghetto!)
post #20 of 27 Old 02-19-2013, 09:04 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3080
post #21 of 27 Old 02-19-2013, 09:07 PM - Thread Starter
Much crisper than the receiver... Much smaller, and a lot better sound stage.
post #22 of 27 Old 02-19-2013, 09:55 PM
cel4145's Avatar
Quoted: 2657 Post(s)
Liked: 2987
Glad you like your speakers!
Find a smaller, old wooden cigar box on ebay and drill some holes. That would look better than the box it came in smile.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #23 of 27 Old 02-19-2013, 11:26 PM - Thread Starter
I was thinking of something like that... Thanks for the rec!
post #24 of 27 Old 02-20-2013, 10:07 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3080
post #25 of 27 Old 02-20-2013, 10:15 PM - Thread Starter
I might stick with the box, it doesn't stand out...
post #26 of 27 Old 03-15-2013, 03:24 PM - Thread Starter
Dang, should've gotten those Cambridge ones... actually, there were some Kef IQ30s the other day for $320 a pair... frown.gif Might ask for suggestions for a $300-400 pair later though...
post #27 of 27 Old 03-29-2013, 10:13 PM - Thread Starter
Okay, recs for under $400? I'll be getting a cheap (Under $200) sub and a better (~$500 later).
Reply Speakers
