Need help connecting active speakers to a laptop. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-25-2013, 05:14 PM - Thread Starter
veegee92's Avatar
Hi, so I'm about to get a pair of Emotiva Airmotiv 5s (has RCA and XLR) and I just wanted to know what would be the best way i could hook it up to my macbook pro so as to get the best audio quality out of them. Would I need an external sound card? Anything else? I'm pretty new to this so any help would be appreciated!
veegee92 is offline
post #2 of 8 Old 01-25-2013, 05:32 PM
PCMusicGuy's Avatar
Easiest way would be to just use a 3.5mm stereo plug (headphone) to 2 RCA "y" cable (see example at link below). I would recommend trying that first and see how you like the sound. After that, you are looking at either a USB DAC or standalone DAC or Receiver with an optical input.
http://www.mycablemart.com/store/cart.php?m=product_detail&p=2300
PCMusicGuy is offline
post #3 of 8 Old 01-25-2013, 05:53 PM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2990
Agreed. Try hooking it up without a DAC first. You might be satisfied without one.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #4 of 8 Old 01-25-2013, 08:36 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
I have the Airmotiv 5's and currently have them connected directly to my computer using a $3 3.5mm to RCA adapter. I'm looking at either the Emotiva XDA-2 DAC or possibly the UMC-200 7.1 prepro so I can also use it as an HDMI+Audio switcher for several computers I have in my computer room. Emotiva has a couple more DACs/Processors coming down the pike that will probably have both analog and digital inputs, namely the Stealth DC-1 and Executive Pre-1. These two will be half-rack, 2U boxes instead of a full-rack box.
I'm getting absolutely NO background hum/noise on the Airmotiv 5's using the built-in Realtek ALC-889 chipset with an analog connection.
I'd consider the Emotiva XDA-2 because there are very few, if any, DACs in the $400 range that use the C-Media 6631 USB chipset that can stream 24/192 via USB. The only real negative is the lack of analog input on the XDA-2 for tape decks, turntables, etc.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #5 of 8 Old 01-25-2013, 10:16 PM
cel4145's Avatar
Liked: 2990
But I think the OP could do very well without spending that much. For instance, I just bought the ODAC built by JDS Labs for $149. Would work great with your speakers. Nice thing about it for laptop use is that's tiny. Here it is next to my G400 mouse
Ever want to add a headphone amp to it, you'd have a nice portable setup to use with your laptop and good cans.
cel4145 is offline
post #6 of 8 Old 01-26-2013, 08:37 AM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
Yes. I actually took a look at this DIY design when I was researching DACs. That would be fine for a single source in using UAC1 but you'd still have the lack of 24/192 and 24/88 over USB. Any media in those formats would have to be down-sampled to 24/96 or 24/44. Getting the option for an analog input ( headphone amp ) would push the price to nearly $300 with the adapter. That is only $100 less than the XDA-2, which would be way more versatile and $300 less than the UMC-200, but we are talking about HUGE chassis compared to even the O2+ODAC. I'd probably opt for the Audioengine D1 at $170, which has the headphone input and supports all the proprietary SACD formats in a size that is about twice as thick as the ODAC... the differences between the AKM and ESS Sabre DAC not withstanding.
jevans64 is offline
post #7 of 8 Old 01-26-2013, 09:37 AM
cel4145's Avatar
Liked: 2990
A majority of people don't own any music at that sampling and bit rate since CDs are 16/44, and even most bluray is only 24/48. And even if they did, I suspect that most would find it difficult (if not impossible) to tell the difference between the downsampled version and the original with a $500 pair of studio monitors. Even the XLR connections on those speakers are probably more beneficial as a marketing gimmick for Emotiva than they are useful for producing better audible sound.
cel4145 is offline
post #8 of 8 Old 01-26-2013, 10:19 AM
UofAZ1's Avatar
Quoted: 50 Post(s)
Liked: 75
If you find your getting a buzzing from your powered speakers just attach a ground loop isolator between the RCA connectors and speakers. Worked for me.
UofAZ1 is offline
Reply Speakers
