How to camoflauge speaker wires ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-26-2013, 02:25 AM - Thread Starter
Jim McC's Avatar
Quoted: 116 Post(s)
Liked: 58
I have my 3 front speakers on a shelf, and the wires tend to hang down under the shelf and are visible. The reason they are visible is the wall is painted black, and the wires are light gray. What suggestions do you guys have to hide or camoflauge the wires? Thanks.
One idea I had was to put that black wire protector stuff over the wires, so it blends in with the black wall.
Jim McC is offline
post #2 of 9 Old 01-26-2013, 02:57 AM
GaryWA's Avatar
Quoted: 16 Post(s)
You can also route them however you want using Command strips hooks. That's what I did with my ethernet run.
GaryWA is offline
post #3 of 9 Old 01-26-2013, 05:21 PM - Thread Starter
Jim McC's Avatar
Quoted: 116 Post(s)
Liked: 58
Thanks Gary, but I don't see how using those white things on my black wall helps to hide the wires. Are you saying paint them black?
Jim McC is offline
post #4 of 9 Old 01-26-2013, 05:28 PM
XStanleyX's Avatar
Liked: 1269
XStanleyX is offline
post #5 of 9 Old 01-26-2013, 05:32 PM
Bill Fitzmaurice's Avatar
Liked: 4767
Get black wires.
Bill Fitzmaurice is offline
post #6 of 9 Old 01-26-2013, 05:52 PM
afrogt's Avatar
Quoted: 1063 Post(s)
Liked: 769
You could get these cord channels and paint them black.
http://www.cableorganizer.com/wire-cover/
These come in black
http://www.cableorganizer.com/surface-raceways/latching.html
Afro GT
afrogt is online now
post #7 of 9 Old 01-26-2013, 05:54 PM
GaryWA's Avatar
Quoted: 16 Post(s)
Hm. I wasn't really thinking. I would get some cable conduit like some people in here have mentioned.
GaryWA is offline
post #8 of 9 Old 01-26-2013, 06:51 PM - Thread Starter
Jim McC's Avatar
Quoted: 116 Post(s)
Liked: 58
Originally Posted by XStanleyX View Post
You could run the wire through this: http://www.monoprice.com/products/product.asp?c_id=105&cp_id=10520&cs_id=1052005&p_id=7119&seq=1&format=2
They also have it in 1" diameter.
Thanks guys. I think my Home Depot has this stuff, and it has a slit in it I think.
Jim McC is offline
post #9 of 9 Old 01-26-2013, 07:36 PM
XStanleyX's Avatar
Liked: 1269
Yes it does have a slit along it's length. Most hardware stores usually carry it.
Reply Speakers
