Importance of range - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-27-2013, 10:52 AM - Thread Starter
crcostel's Avatar
Quoted: 45 Post(s)
I am running Polk M30ii/CS1 front. I recently got a MS Carnival 9 Sub and love its look/feel. I was thinking of replacing the rest but the only fronts that would fit in my space are Carnival 1's with a claimed range of 90hz (m30 is 55hz). Would those speakers just be awful or can I set my crossover at 90/100 and be happy? Thanks!
crcostel is online now
post #2 of 7 Old 01-27-2013, 11:00 AM
Elihawk's Avatar
Quoted: 1016 Post(s)
Liked: 860
I very much doubt the m30 can hit 55 hz at a decent volume.
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
post #3 of 7 Old 01-27-2013, 11:04 AM - Thread Starter
crcostel's Avatar
Quoted: 45 Post(s)
That doesn't surprise me. Is that typical or just a Polk budget feature. I guess what I mean is would the MS 1's have a real range in the 120's or are they more honest.
post #4 of 7 Old 01-27-2013, 01:38 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
What is your size restriction - and your max budget? The Polk has more boom than depth.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #5 of 7 Old 01-27-2013, 01:58 PM - Thread Starter
crcostel's Avatar
Quoted: 45 Post(s)
Size is 11.5" height. (Ouch). Which rules out all of the Polks except M30 and Tsi100. It also rules out the Carnival 2. A4L has the Carnival 1's for $120. They are sealed, 85db, 90-20khz
Figure budget is 200, less is always better. WAF is key - it has to be cherry/oak to match the sub.
post #6 of 7 Old 01-27-2013, 02:13 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
The Cambridge/Mordaunt Short company - tend to do pretty good with their speaker specs.
The Carnival 1 should be decent between 100 to 120 hz.
I would still look at the Cambridge Audio S30, if you can squeeze/stretch the budget, and get
the wife approval - and if they are not going into a cubby hole. They do have good tight bass,
and plays down to 60 hz.
http://www.amazon.com/Cambridge-Audio-Speakers-Dark-Pair/dp/B004NDN9NK/ref=sr_1_2?ie=UTF8&qid=1359320645&sr=8-2&keywords=cambridge+s30
Who AM I
zieglj01 is offline
post #7 of 7 Old 01-27-2013, 02:38 PM - Thread Starter
crcostel's Avatar
Quoted: 45 Post(s)
It would go into a bookcase with open back, but against a wall. Shelves are 12.5" deep. Conversely I have tons of room for the center so I might keep the m30s and get a cs2/25c
Reply Speakers
