Compact sound solution for my family room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-27-2013, 05:30 PM - Thread Starter
MEA707's Avatar
I've got a fairly restrictive living room setup, with a 42" Hitachi TV (2010 model) that fits nice and snug in the corner next to the fireplace at a slight angle for better viewing.
Here is the layout:
I know I open more possibilities by mounting the TV above the fireplace, but it's just too high for my personal preference.
For an LCD, this TV produces pretty reasonable sound. You can see it has a pretty thick bezel below the screen which houses the two front facing speakers (not your typical tiny down or rear-facing speakers). I tried out the Yamaha YAS-101 soundbar, and while I was very happy with the sound, I am returning it because it's blocking the IR remote receiver on my TV and the IR repeater on the soundbar can't reach the location of the IR receiver on the TV, so I need to try something different, preferabbly a compact speaker/subwoofer set up.
I know my options are limited based on my room layout, but would like to hear any suggestions for any potential sound improvements I can implement.
Thanks in advance for any help.
MEA707 is offline
post #2 of 6 Old 01-27-2013, 05:36 PM
zieglj01's Avatar
Quoted: 1570 Post(s)
Liked: 1427
What is your max budget?
__________________________________________
Who AM I
Speakers -- Snell K7 > Q Acoustics 3020 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #3 of 6 Old 01-27-2013, 06:30 PM - Thread Starter
MEA707's Avatar
Under $500 preferably.
MEA707 is offline
post #4 of 6 Old 01-27-2013, 06:45 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
That is a REALLY tough space, I never recommend soundbars, but in this case I think its your best choice. If the base of your tv is 6.5" deep or less you could sit it on top of this 42" wide sound bar (you could also get a couple 4x4's from lowes to extend the platform behind the soundbar that your tv would rest on)
http://www.parts-express.com/pe/showdetl.cfm?partnumber=303-442
A budget sub and receiver would round out the setup.
Jay1 is offline
post #5 of 6 Old 01-27-2013, 07:19 PM - Thread Starter
MEA707's Avatar
Interesting, can this soundbar really support the weight of a 42" LCD TV?
MEA707 is offline
post #6 of 6 Old 01-27-2013, 07:29 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
I dont see why not. It's a 8" x 6.5" x 42" rectangle made out of wood, it should be plenty sturdy with only around 40lbs sitting on top. It weighs 35 lbs its self, so it is pretty solid.
Jay1 is offline
Reply Speakers
