How do I run two left and two right speakers with a passive sub? - AVS Forum | Home Theater Discussions And Reviews
Old 01-27-2013, 09:35 PM - Thread Starter
Ukraine Train's Avatar
I'm setting up a budget system where I need a set of speakers off the same receiver outputs in two different rooms. The receiver is rated for 8-16ohm and the speakers and passive sub I have are all 8ohm. I know typically I can run two speakers in series to get 16ohms but I'd like to incorporate the passive subwoofer in there somehow. I hooked it up like in the diagram below and it seems to work but I don't know if this is safe or if it'll burn something up. I think the sub is normally in series with the single speaker to make 16ohms? So now I'm at 24ohms?
Ukraine Train is offline
Old 01-28-2013, 11:28 AM
Elihawk's Avatar
Quoted: 1016 Post(s)
Liked: 861
Sounds like a bad idea to me. I know there are devices that allow you to switch from speaker set to speaker set!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
Old 01-28-2013, 05:28 PM - Thread Starter
Yeah, I know they make switches. I need all the speakers to be on at once, though.
Old 01-28-2013, 05:32 PM
afrogt's Avatar
Quoted: 1056 Post(s)
Liked: 757
What receiver do you have?
Afro GT
afrogt is offline
