Center speakers: Definitive Technology Mythos Three or MartinLogan Motion 8? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-28-2013, 10:03 AM - Thread Starter
jamsoccer12's Avatar
I'm putting together a home theater and am hoping that someone has experience and can comment on these two. The speaker will sit on a shelf. Right now, I can find the DT speaker for $200 less than the ML. Thank you!
jamsoccer12 is offline
post #2 of 2 Old 01-28-2013, 03:38 PM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
What speakers are you using for your mains? The center should match those as close as possible.
Instead of the Motion 8, you can get a better deal on the Motion C at AudioAdvisors:
http://www.audioadvisor.com/prodinfo.asp?number=MLMOC
They are an authorized dealer.
David
crussader is offline
Reply Speakers
