Kef T305 Speaker System question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-28-2013, 01:15 PM - Thread Starter
Chiefrude1's Avatar
Ive decided to go with the Kef T305 speaker system for my new movie room. I have a noob question I was hoping somebody could please help me with. I want to set up a 7.2 system, I see the surround speakers for the T305 system are the T301's, and the center speaker for the system is the T301c.
Both speaker types seem to me to be identical in all ways except that the surround 301 hangs long ways up (vertical), and the center 301c hangs long ways side to side (horizontal). Could I use the center speaker (301c) as surround speakers? I have an open doorway directly to the right of my seating area so there is not a place to hang the surround 301 speaker, however there is a 12" soffit along the ceiling that would allow me room to hang the center 301c speakers from. I would angle the speaker down toward the seating area. So in short I am hoping I can use 2 of the center 301c speakers in place of 2 of the the surround 301 speakers.
Thank you.
Model T301
Design Two and a half-way closed box
Drive units 2 x 115mm (4.5in.) dual layer MF
25mm (1in.) aluminium HF
Frequency response 80Hz - 30kHz
Crossover frequency 1.7kHz
Amplifier requirements 10 - 150 W
Sensitivity (2.83V/1m) 88dB (floor stand mount)
Maximum output (SPL) 110dB
Impedance 8Ω
Internal volume 1.4 Litres
Weight 1.5kg (3.3lbs)
Dimensions (H x W x D) 600* x 140 x 35 mm
(23.6 x 5.5 x 1.4 in.)
Finish Black
Model T301c
Sensitivity (2.83V/1m) 91dB (wall mount)
Impedance 8Ω
centre mode 140 x 600 x 35 mm
(5.5 x 23.6 x 1.4 in.)
Finish Black
Chiefrude1 is offline
post #2 of 6 Old 01-28-2013, 01:23 PM
Scout's staff's Avatar
In short - yes you can use two centers as surrounds. Some surround speakers are designed with speakers aimed in opposite directions aiding in sound filed dispersion, but many folks here use old main speakers or bookshelf speakers as surrounds as well.
Scout's staff is offline
post #3 of 6 Old 01-28-2013, 02:27 PM - Thread Starter
Chiefrude1's Avatar
Thank you, I figured I could but just wanted to be sure.
post #4 of 6 Old 01-29-2013, 01:57 AM
Jonathan Lau's Avatar
Curious what receiver you are using also? Thanks.
Jonathan Lau is offline
post #5 of 6 Old 01-29-2013, 05:07 AM - Thread Starter
Chiefrude1's Avatar
Im going to be using a Denon AVR-2113CI. Ill be using a splitter to run two subs as there is only 1 output. I read a post on here that said that was possible.
post #6 of 6 Old 01-13-2014, 02:06 PM
abe726's Avatar
hey man,
how did t305 work for you, i narrowed mine down to def tech 1000 and t305,  please let me know how did this work for you, i have a 20x18 living room with 9ft ceiling
abe726 is offline
Reply Speakers
