Subwoofer to PC, please help new here - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-29-2013, 01:29 PM - Thread Starter
V12 Commander's Avatar
Can I connect a subwoofer to my PC? the thing is i have 2 speakers connected and there is no audio port left for a sub? how can it be possible thanks and I know nothing about speakers.
Thanks Again!
V12 Commander is offline
post #2 of 8 Old 01-29-2013, 03:51 PM
scupking's Avatar
Quoted: 29 Post(s)
Should be able to use a stereo Y splitter. Hook your PC speakers up to one of the female connections and the sub up to the other. See link below
http://www.amazon.com/Belkin-Speaker-and-Headphone-Splitter/dp/B000067RC4/ref=pd_cp_e_0
Then you would need this going from the sub to one of the connectors on the above splitter.
http://www.amazon.com/dp/B004YEBK66/ref=pe_175190_21431760_M3T1_ST1_dp_1
scupking is offline
post #3 of 8 Old 01-30-2013, 05:38 AM - Thread Starter
Yeah but my sub has wires like this, how do i connect that? Thanks, and i know nothing about speakers.
post #4 of 8 Old 01-30-2013, 05:52 AM
eljaycanuck's Avatar
Quoted: 1346 Post(s)
Liked: 1962
Yes, if you have i) a sound card with a subwoofer output and ii) a powered sub.
... my sub has wires like this ...
That would appear to indicate that your sub is passive (i.e., not powered). You'd need to connect your sound card's subwoofer output to a power amplifier of some sort, and then connect the sub to the speaker-level outputs of that amplifier.
eljaycanuck is offline
post #5 of 8 Old 01-30-2013, 12:55 PM - Thread Starter
post #6 of 8 Old 01-30-2013, 03:09 PM
Liked: 1962
Work how? That's a powered sub so, yes, it could replace your passive sub. But you still need to be able to send a signal to it.
post #7 of 8 Old 01-31-2013, 10:52 AM - Thread Starter
send a signal? sound card? im not a professional in speakers guys, why you using fancy words and that?
post #8 of 8 Old 01-31-2013, 11:04 AM
Liked: 1962
The (audio) signal is the unamplified sound. Send it to an amp + speakers (or to powered speakers) and you have sound.
To get the (audio) signal out of the computer, you need a sound card. You currently have your speakers connected to one. If the sound card has a subwoofer output, you can connect a subwoofer as well. If it doesn't, you need a new sound card.
Reply Speakers
