Wall mounting my Energy Veritas V-Mini Center - Help Please!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-29-2013, 05:13 PM - Thread Starter
OilCountry82's Avatar
Hi guys,
I'm struggling with mounting my Energy Veritas V-Mini Center channel speaker. Given my set up, wall mounting is the only option.
Both bookshelf mini`s came with a mount so no issues there. I e-mailed OmniMount and they`re asking what the thread size on the back is. Can anyone tell me or provide options.. Thank you!!
OilCountry82 is offline
post #2 of 10 Old 01-29-2013, 05:36 PM
GaryWA's Avatar
Quoted: 16 Post(s)
What about a stand?
GaryWA is offline
post #3 of 10 Old 05-07-2013, 07:25 PM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
Originally Posted by OilCountry82 View Post
Hi guys,
I'm in the same situation, what did you wind up doing?
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #4 of 10 Old 05-08-2013, 12:34 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
its the same thread pattern as your other V mini bookshelf speakers.
Take the screw out of the back of the speaker and you'll know the size and pattern.
Easiest way to wall mount the center is to just build a small shelf or use two brackets like this.
http://www.amazon.com/Pinpoint-Center-Channel-Speaker-Mount/dp/B002MP5JX4/ref=pd_cp_e_0
Afro GT
afrogt is offline
post #5 of 10 Old 05-08-2013, 05:19 AM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
I'm not sure that is stable enough if mounting vertically, near a busy door.
ISF Calibrator
Samsung PN64F8500
dsskid is offline
post #6 of 10 Old 05-08-2013, 11:06 AM
afrogt's Avatar
Liked: 755
Oh you're trying to mount the center vertically?
Afro GT
afrogt is offline
post #7 of 10 Old 05-08-2013, 04:54 PM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
yes alongside the tv. Otherwise the bracket you linked would have done the trick.
ISF Calibrator
Samsung PN64F8500
dsskid is offline
post #8 of 10 Old 05-14-2013, 02:27 PM
mantrika's Avatar
Wondering if you found a good solution for mounting VMINI CC vertically? Would a pair of brackets that comes with VMINIs work for the CC if they are bought seperately.
Trying to help a friend who is in a similar situation to yours. He wants to mount CC vertically for L/R position.
mantrika is offline
post #9 of 10 Old 06-30-2013, 08:15 PM
lungin's Avatar
Anyone able to confirm the thread size on the v-mini bookshelf? Included brackets aren't going to work. Need to get ceiling mounts and want to get the right ones.
lungin is offline
post #10 of 10 Old 09-30-2013, 05:58 PM
pghflyer's Avatar
Anyone figure this out? I am hoping to figure out a way to mount my V-mini bookshelves and center to my wall mount (VideoSecu MW380B) for my Panasonic TC-P55GT50, which I think has VESA 500X300.
Curious about this Monoprice for the L/ R speakers:
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10828&cs_id=1082804&p_id=9900&seq=1&format=2
May try to retrofit some universal soundbar mounts for the Center:
http://www.amazon.com/Bentley-Mounts-Universal-Soundbar-Bracket-black/dp/B00873FGP6/ref=sr_1_6?s=electronics&ie=UTF8&qid=1380585159&sr=1-6&keywords=soundbar+mount
I have to say it has been a hateful task trying to figure out how to align all of these TV/VESA/Mount/Weight/Articulation/SupplementalMountingBrackets/SpeakerMountConnections/etc/etc.....
pghflyer is offline
Reply Speakers
Panasonic Viera Tc P55gt50 55 Inch Plasma Tv
