toslink-tv to powered speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-29-2013, 05:41 PM - Thread Starter
tongr's Avatar
If I connect my tv to a pair of powered speakers via optical cable can I control the volume with the tv volume? If the speakers have a volume knob then that would that serve as a "gain" control?
tongr is offline
post #2 of 4 Old 01-29-2013, 07:50 PM
jevans64's Avatar
Quoted: 204 Post(s)
Liked: 160
Most TV's made in the last 10 years have the option of having static or variable volume control on the audio outputs. It is going to be an audio option in the TV's settings. You would turn any volume control on the speakers all the way up and set the TV to output variable volume.
I don't know of too many powered speakers that have an optical input unless they are part of a HTiB. Those that do will have a built-in DAC, which you would need if you have speakers without digital inputs but want to use S/PDIF or TosLink. Cheap portable DACs usually run $40 to $60 with better ones with headphone output and higher resolution running $150 and up.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #3 of 4 Old 04-21-2013, 12:18 PM
slyvella's Avatar
Have you found speakers that connect by toslink cable? I have a bedroom TV and that's its only audio output. No room in the bedroom for an A/V receiver. All the soundbars and small speakers I've found require a headset jack, or RCA audio.
slyvella is offline
post #4 of 4 Old 04-21-2013, 12:32 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
You can always get an inexpensive DAC, such as the FiiO D3. It's tiny, and could be hidden away. Then you can plug whatever powered speakers you want into it.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
Reply Speakers
