Anyone experiencing CL-4 Problems? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-29-2013, 08:38 PM - Thread Starter
KernsFunk's Avatar
I received a pair of CL-4s last week. One of the speakers I was shipped had an odd rattle behind the tweeter when I moved the speaker. Gallo kindly just sent me a replacement, but the new one has an even more noticeable rattle. Sounds kind of like a spray paint can when you move it around. The other one I was originally sent is solid and makes no noise.
I just sent an e-mail back to Gallo to see if this is a common problem. Has anyone else experienced this?
KernsFunk is offline
post #2 of 3 Old 01-30-2013, 04:14 AM
OldMovieNut's Avatar
You might want to remove the screws pull the tweeter out and take a look. It's very easy to do.
Cheers,
OldMovieNut
OldMovieNut is offline
post #3 of 3 Old 01-30-2013, 07:22 PM - Thread Starter
KernsFunk's Avatar
Not a bad idea, but I have them on a 60-day trial. I'm waiting to hear back from Bill Fried at Gallo and will suggest this if he has no answers
Reply Speakers
