Polk Monitor 40 as a center speaker or buy a ProCenter 1000? - AVS Forum | Home Theater Discussions And Reviews
Old 01-29-2013, 10:34 PM - Thread Starter
alaskajoel's Avatar
So I currently have 2 Monitor 50s up front and 2 Monitor 30s as surrounds. I'm shopping for a center speaker, but the catch is the location for the center is only 17" wide--ruling out the CS1, CS2, CS10, Etc....
I was going to buy a ProCenter 1000 since I loved the sound so much when I listened to it at the store, but I also have easy access to a Polk monitor 40 which would fit in the opening on its side. Which of these would be the better option? Is there a problem with using a monitor 40 as a center? I know it is more similar to the other speakers in the stable, but I also really liked the ProCenter 1000...alas I haven't heard it with the rest of my setup. Suggestions? Receiver is a Pioneer VSX-1021 for what it's worth.
alaskajoel is offline
Old 01-29-2013, 11:13 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
use the monitor 40. the procenter 1000 center will not be timber matched to your monitor 50s, where as the monitor 40 will.
I don't need snobs to tell me how to think, thank you!
67jason is offline
Old 01-30-2013, 06:15 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
x2
crazyrob425 is offline
Old 01-30-2013, 06:34 AM
Elihawk's Avatar
Quoted: 1081 Post(s)
Liked: 909
x3
However, you may have to buy a pair of M40s! I have seen them sold as singles...
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is online now
Old 03-24-2013, 10:13 PM - Thread Starter
alaskajoel's Avatar
Just an update with what I did. I took everyone's advice and bought am M40 from a buddy of mine who only had one to sell... (the other one met an unfortunate death at the hands of a toddler)
I'm super happy with this decision as it basically sounds exactly like the speaker it replaced and fits in the hole perfectly. I'm using a foam speaker stand to angle it up about 5 degrees and it's great. Thanks everyone.
