Which lends itself to creating a wider sound stage... Speakers or Reciever? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 01-29-2013, 10:44 PM - Thread Starter
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 37
Still researching... One of the things I long for...want desperately...is immersive..3d sound for my HT.
I was wondering which was a bigger componet of gettign that enveloped 3d sound stage... A reciever or the speakers?
I noticed when I auditioned PSB speakers ....the sound stage was weak compared to same reciever with the Klipsch. Don't get me wrong...totally different sounding speakers...but the envelopment factor heavily went to the Klipsch. I ended up not loving the "brightness" but they for sure seemed to envelop me better.
Newbie01 is offline
post #2 of 11 Old 01-30-2013, 01:22 AM
GaryWA's Avatar
Quoted: 16 Post(s)
Speakers, then room correction software.
GaryWA is offline
post #3 of 11 Old 01-30-2013, 01:43 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
room, then speakers, then room correction, then source......then perhaps the receiver/processor.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #4 of 11 Old 01-30-2013, 03:46 AM
WagBoss's Avatar
room, then speaker placement, then speakers, then room correction, then source, then receiver/processor
WagBoss is offline
post #5 of 11 Old 01-30-2013, 06:07 AM
Troll
ufokillerz's Avatar
Liked: 48
definitely speakers, some speakers make your room sound way bigger then it actually is!
ufokillerz is offline
post #6 of 11 Old 01-30-2013, 06:22 AM
jaymalya's Avatar
My previous speakers ( Mirage OM-9) was great in that respect - it had a big sound stage
jaymalya is offline
post #7 of 11 Old 01-30-2013, 06:27 AM
eljaycanuck's Avatar
Quoted: 1351 Post(s)
Liked: 1964
Speakers.
eljaycanuck is offline
post #8 of 11 Old 01-30-2013, 06:37 AM
Elihawk's Avatar
Quoted: 1340 Post(s)
Liked: 1172
I would assume that most receivers have an sound/adobe setting that widens the stage (de-emphasis of the center)....but that won't widen the sound coming from any individual speaker...just change the mix a bit!
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #9 of 11 Old 01-30-2013, 06:51 AM
craig john's Avatar
Quoted: 564 Post(s)
Liked: 802
The best way to be "enveloped" by sound is to be surrounded by speakers. Therefore, getting a receiver or pre/pro with multiple channels will provide "surround sound" and the more channels, the more enveloping the surround sound. 5.1 is good, 7.1 is better, 9.1 better still and 11.1 is the best that is currently available. Of course, you'll need speakers for all those locations also. Therefore, the question is not which is more important... both are essential to the experience.
Now, if you're just talking about 2-channel reproduction, then the speakers will have the biggest impact on the soundstage width. Still, there is no 2-channel system that is "enveloping" unless it uses some kind of sonic trickery.
Craig
Lombardi said it:
"Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #10 of 11 Old 01-30-2013, 06:54 AM
MNaudioguy's Avatar
Quoted: 59 Post(s)
room correction software outside of Audyessy? if so, what is it, is it fairly dummy proof if you spend the time researching a little?
MNaudioguy is offline
post #11 of 11 Old 01-30-2013, 07:47 AM
Elihawk's Avatar
Liked: 1172
The Bose 901 speaker is designed to provide enveloping sound by bouncing sound all over the place. I have heard that is your room is just right, these speakers can provide a very encompassing sound. however, you won't get any lows and poor highs...
Elihawk is offline
Reply Speakers
