Speaker options for new home theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 01-30-2013, 12:06 PM - Thread Starter
letzleta's Avatar
I am constructing a basement home theater. I will be using equipment from my previous home theater but I am considering upgrading my speakers during construction.
Here are the old setup:
H/K AVR247
Optoma HD70
PS3
Oppo DVD/SACD player
JBL E30's all around
DIY Sonotube 15" Dayton Titanic sub (tuned to 18hz)
H/K multi-disc CD player
Technics record player
Usage:
70% Movies/TV
30% Music/Concerts
Room is 17.5' x 14' (actual room is more like 17.5 x 28, but support beams separate the room and half is consumed by a pool table)
The speakers must be bookshelf, wall mount, or in wall. I want to keep the speakers off the ground and out of reach of children. I have 6 JBL E30's and could use them, however, I do not have a matching center channel and have not been able to find one. Also, I would have to build shelves of some sort or figure out a way to mount them to the walls. This is why I was leaning towards on/in-walls. The room currently has a giant built in corner entertainment center that houses a 37" tube TV. The corner unit is nice, however, the TV is built in so I am going to have to tear the entire thing out. The plan is to tear all the drywall out and redo the room, so the options are numerous.
I would like to stay as close to $1000 as possible, but could potentially go as high as $1500. DIY is not completely ruled out, however, I am not sure I have the time for it. I would like to do a 7.1 setup, however, could stick with 5.1 for now and expand to 7.1 in the future.
So, in summary, what would you all recommend for a 5 or 7 speaker setup with ~$1000 budget?
I was looking at the following for an on wall setup:
Center: JBL LC2 ~$290
Fronts: JBL L820 ~$350 per pair
Rears: either
JBL L820's
or
JBL L810's ~$280 per pair
Secondly, is it even worth upgrading from my JBL E30's in this price range or should I just try to find a center channel that matches?
letzleta is offline
post #2 of 14 Old 01-30-2013, 07:46 PM - Thread Starter
letzleta's Avatar
Any opinions?
letzleta is offline
post #3 of 14 Old 01-31-2013, 06:59 AM
JimWilson's Avatar
Quoted: 1497 Post(s)
Liked: 1990
Do you like the JBL speakers? If so, why not use one of them horizontally as your center? With 6 you still could do a full 5.1 system.
SimpleTheater likes this.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #4 of 14 Old 01-31-2013, 07:35 AM - Thread Starter
letzleta's Avatar
I have enjoyed the JBL's, and that is how I had them setup in my previous 5.1 setup (horizontal center). The only drawback is the depth of the box, they are at least a foot deep. I am not ruling this option out, however, this limits my ability to go to a matching 7.1 setup.
Maybe the question I should have asked is, can I improve significantly from the E30's with $1000 budget? For example, will the setup described above improve my sound significantly. Another option would be just purchasing the front 3 speakers and using the E30's for rears, or some combination of in-wall/in-ceiling rears and bookshelf/on-wall LCR.
One thing to note that I haven't mentioned previously is that I am going to have trouble placing the right side surround speaker due to the room layout. The rear surrounds can be on the rear wall, but with my proposed layout, the right side is open to the pool table. That is why I was considering a in-ceiling solution for the side surrounds (in a 7.1 setup). Is this a bad idea? I could put it on the wall, but it is ~15 feet from the right side of the seating, where the left would be ~2 feet from the left side.
I have so many ideas running through my mind. That is why I made this thread.
letzleta is offline
post #5 of 14 Old 01-31-2013, 08:01 AM
Ab Liquor's Avatar
I'm no pro, but I just bought 8 Def tech promonitor 350's, and a klipsch rw12-d sub for my first home theater. I they are gonna be in my basement also which has a open layout and measures 19'W x 40'L. Heard they were very good speakers, and most reviews I have read have been very positive on both the speakers and sub. I got them from Newegg and the entire setup without the receiver cost me a little over $1000. I'm going to be using them in a 7.1 setup with a 350 as my center, I will have a extra 350 laying around cause It was cheaper to buy them in pairs. Good luck hope this helps, you can check out my thread and see what others recommended for me also.
http://www.avsforum.com/t/1454964/noob-question-about-new-speakers-and-receiver-ht/60#post_22894004
Sent from my SCH-I535 using Tapatalk 2
Ab Liquor is offline
post #6 of 14 Old 01-31-2013, 08:03 AM
JimWilson's Avatar
Liked: 1990
Without ever having heard the E30's I can't really say what might provide a "significant" improvement, but I can point you at Ascend Acoustics. Their CMT-340 SEC center and 4 CMB-170 SE's would come in under $1000 and give you one very nice setup.
post #7 of 14 Old 01-31-2013, 08:07 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 567
It may be tough to improve on your current speakers at that budget level.
An excellent center speaker that I would recommend to you is the Cambridge S50.
It should work well with your system.
If you play LPs much, you might want to invest in something like the Music Hall MMF-2.2 turntable , which will be a noticeable improvement over your existing one.
Mounting wood shelves is not a problem; just use metal L-brackets with the vertical part screwed to the wall so that it will be behind the speaker and the horizontal under the shelf, and they are invisible with the speaker in place.
Since you are stripping the drywall, you can mount a 2 x 12 between the studs at each speaker location to provide a very strong place to put in the screws for the shelves.
commsysman is offline
post #8 of 14 Old 01-31-2013, 08:28 AM - Thread Starter
letzleta's Avatar
Those look like nice speakers. If I end up going with them, I will shoot you a PM about potentially purchasing your extra one from you! Thanks.
letzleta is offline
post #9 of 14 Old 01-31-2013, 08:32 AM - Thread Starter
letzleta's Avatar
How are you able to tell the S50 would mate well with my E30's? I am not challenging that suggestion, just want to understand how I can tell what will mate (timbre match) with the E30's. I tried to get an EC35 a while back, but couldn't get my hands on one.
letzleta is offline
post #10 of 14 Old 01-31-2013, 08:40 AM
zieglj01's Avatar
Quoted: 1535 Post(s)
Liked: 1370
Look at the HTD Level Three speakers - they are real good
http://www.htd.com/Products/level-three-speakers
They also have in-ceiling/in-wall speakers for surround help
http://www.htd.com/Products/high-definition
__________________________________________
Who AM I
Speakers -- Snell K7 > Digital Phase AP-.5 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is offline
post #11 of 14 Old 01-31-2013, 04:18 PM
Ab Liquor's Avatar
that sounds good, i should be receiving the entire system tomorrow, i will let you know how that goes, and sounds once install is done, i can't wait biggrin.gif
post #12 of 14 Old 02-06-2013, 09:17 AM - Thread Starter
letzleta's Avatar
One other option would be:
Rears: JBL E30's (already own)
This option would only end up costing me ~$600 and I think it would improve my setup.
letzleta is offline
post #13 of 14 Old 02-06-2013, 08:45 PM
Bob7145's Avatar
Liked: 36
letzleta,
If you can't find a center you are looking for (keep looking) then another E30 for center would do fine and also the least expensive option.
I liked the Studio L series so much that I snagged all of them and changed configurations every so often just for fun. The L830 and L810 make a good match together and sound a little different then the L820s so IMHO would not mix L820s with L810s or L830s.
The L820s make good surround speakers but with their single 6" woofer may sound a little on the weak side as Mains.
The LC2 is one heck of a speaker (basicly a wall mounted L880!) and many folks have used 3 of them across the front, even as surrounds also. I eventually ended up with 3 L880s in the front with L820s as surounds for the living room and the L830/LC1/L810 combo in the bedroom.
Have fun.
Bob7145 is offline
post #14 of 14 Old 02-06-2013, 09:02 PM
Elihawk's Avatar
Quoted: 1323 Post(s)
Liked: 1157
I really like the ascend cmt340s, so I second that recommendation!
Commysman, you are the only poster I know who often recommends mismatched centers! I would recommend a timbre match across your front stage!
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
Reply Speakers
