Bookshelf Speakers with Low frequency extension - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 01-30-2013, 01:30 PM - Thread Starter
boardinguy100's Avatar
Quoted: 13 Post(s)
Hi, I was wondering what other options there are for bookshelf speakers that play pretty low. This is for music only without a sub and nearfield listening. I'm currently using energy Rc10's and they go down to 50Hz(give or take a few) I'm looking at either Ascend Acoustics Sierra-1, or Tekton Design M lore monitors. Any others I should consider? Budget is $1000.
boardinguy100 is offline
post #2 of 19 Old 01-30-2013, 01:35 PM
Bill Fitzmaurice's Avatar
Liked: 4628
50Hz is about as low as you can reasonably expect from bookshelfs unless they're pretty large, loaded with at least 8 inch woofers.
Bill Fitzmaurice is online now
post #3 of 19 Old 01-30-2013, 01:57 PM - Thread Starter
Quoted: 13 Post(s)
Agreed, thats why I was looking at the Sierra-1's(Typical In-Room Frequency Response 39Hz - 22kHz ± 3dB) and the Tektons (Frequency Response 38Hz-20kHz) the tektons have an 8" driver. I was wondering what others might suggest.
post #4 of 19 Old 01-30-2013, 02:09 PM
WagBoss's Avatar
monitor audio silver rx2 go down fairly low with their 8 inch woofers. http://www.monitoraudio.ca/products/silver-rx/rx2/#/specification they're roughly 800-900 i believe.
WagBoss is offline
post #5 of 19 Old 01-30-2013, 02:17 PM
padgman1's Avatar
Def Tech Sm 55 and Sm 65's will (supposedly) go down to 35Hz or so................ Sm55's are $299 each and Sm 65's $499 each on Amazon, can probably do better at other sites ( Newegg, etc)
Some people like them , some don't................
padgman1 is offline
post #6 of 19 Old 01-30-2013, 03:32 PM
RicardoJoa's Avatar
Quoted: 23 Post(s)
Liked: 24
I hate it when manufacture dont list the db point.
RicardoJoa is offline
post #7 of 19 Old 01-30-2013, 03:44 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
Deftech badly exaggerates the extension on all of their products. If you don't need something beautiful looking, there are some pretty beefy studio monitors that really do have good extension. One to look at is the JBL LSR2328, that is a pretty heavy duty active monitor. Up your budget a bit more and check out the Mackie HR824 mk2, it has a large 8.75" woofer with a 150 watt LF amp and claims to have a response of 37Hz-20kHz (+/- 1.5 dB). That is terrific extension. The KRK VXT-8 also has a claimed Frequency response of 40Hz-22kHz (+/-1.5dB). I don't know the tolerances for the KRK Rokit 10-3, but with that 10" woofer and KRKs claim of a 30 hz extension, that is going to have some serious bass, no doubt. It is a big speaker though, but not a tower speaker, and it also hits your budget at $1k shipped almost exactly.
shadyJ is offline
post #8 of 19 Old 01-30-2013, 03:55 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
The SM 55 is -3 db at 44 hz
The SM 65 is around 43 hz
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #9 of 19 Old 01-30-2013, 08:42 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3074
The Sierra-1s have very good bass for book shelf speakers. I would highly recommend them.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #10 of 19 Old 01-30-2013, 09:47 PM
sonex's Avatar
If you don't mind building a kit, for near field speakers DIY sound group has the nano neo's that get down to 40 hz in a .32 cu ft cab and there is the hit makers that get down to 42hz in a .5 cu ft cab. Both speakers can be built for less tha 200 bucks and that includes pre cut cabs. They both sound extremely nice and will fit on a desk easily no sub needed.
sonex is offline
post #11 of 19 Old 01-31-2013, 09:30 AM - Thread Starter
Quoted: 13 Post(s)
Thanks everyone for the help. Now I have a few other options to consider.biggrin.gif
post #12 of 19 Old 01-31-2013, 10:30 AM
gtpsuper24's Avatar
Liked: 99
The Arx A1b bookshelf is a great bookshelf with deep extension. Frequency Response: 52Hz-22kHz +/- 3dB Its a 5.25" woofer but with the XBL2/Splitgap drivers with huge excursion its has better bass than some 6.5" woofers in its price class and even higher. http://www.theaudioinsider.com/manufacturers.php?mPath=13
This is the 1w/1m on axis response of the Arx A1b taken perpendicular to the vertical middle of the baffle. Major vertical divisions are ten Decibels apart and minor divisions are 3.33dB apart. The A1b's response is therefore +/- less than 2dB from the low forties to beyond 20kHz.
gtpsuper24 is offline
post #13 of 19 Old 01-31-2013, 03:05 PM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
Look into the Salk WOW1 - great little speakers with an F3 of 42 Hz cool.gif
But priced at $1200.
rick240 is offline
post #14 of 19 Old 02-01-2013, 08:00 AM
willswing's Avatar
willswing is online now
post #15 of 19 Old 02-01-2013, 08:14 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Agreed. People need to understand that the ear loses sensitivity rapidly below even as high as 1 KHz.
The threshold of hearing at 50 Hz is 40 dB which is the about the same as the noise level in a typical residential room.
In reality, clean SPLs on the order of 100 dB in the bass range are required for satisfying bass.
Now, lets take Salk WOW1 with its 4 1/2 inch woofer that has an Xmax of only 6 mm.
http://www.seas.no/index.php?option=com_content&view=article&id=61&Itemid=85
Freq,Hz Max SPL, DB
10 58
20 70
30 77
40 82
50 86
60 89
70 92
80 94
90 97
100 98
110 100
120 102
130 103
140 104
150 105
160 107
170 108
At 40 Hz this speaker is capable of only a clean 82 dB SPL which is only about 35 dB above the threshold of hearing! Not much of a bass experience.
arnyk is offline
post #16 of 19 Old 02-01-2013, 08:21 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Originally Posted by willswing View Post
Amazing speakers...going low!
http://www.sjofnhifi.com/servlet/Categories?category=%28the+clue%29+loudpseakers
With claims that push on the edges of perception and the laws of physics.
With a 5.5 inch woofer, presumed to have SOTA linear travel:
Freq,Hz Max SPL, DB
10 66
20 78
30 85
40 90
50 94
60 97
70 100
80 102
90 104
100 106
110 108
120 109
130 111
140 112
150 113
160 114
170 115
At 28 Hz it is linear up to only about 85 dB SPL which is only about 20 dB above the threshold of hearing at that frequency. Again, the use of a proper subwoofer is highly recommended!
arnyk is offline
post #17 of 19 Old 02-01-2013, 08:23 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
At the bass end, the dB figure that really matters is the SPL, not the response tolerance.
arnyk is offline
post #18 of 19 Old 02-10-2013, 07:19 PM - Thread Starter
Quoted: 13 Post(s)
Thanks again for the info everyone. I could just keep my Energy RC10's which go down to 50Hz and just get a sub. It would be cheaper but a little more challenging to integrate between PC> ASUS Xonar Essence>Emotiva Mini X amp. I could add an SVS sb1000 and call it a day. Originally I was set on keeping my RC10's when one day I had the house to my self and decided to crank my amp to see how the setup sounded. At half volume it sounded fantastic with plenty of punchy bass( I prefer heavier forms of music) but once I went louder it started to sound (for lack of a better adjective) mushy. It seemed that too a point the extra power made the speakers come alive and then when I pushed it the bass and midrange blended together and not in a good way. Maybe loss of midrange detail.
post #19 of 19 Old 02-11-2013, 04:38 AM
blake18's Avatar
Quoted: 299 Post(s)
Liked: 183
Definitely look into Klipsch Reference RB-81 ii. They extend very low.
Lumenlab "Community driven video lab".
blake18 is offline
Reply Speakers
