Connecting old speakers to Denon AVR-2113CI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-30-2013, 03:02 PM - Thread Starter
Moshe1010's Avatar
Hello,
I've replaced my old Panasonic receiver with a new Denon AVR-2113CI receiver. However, my old speakers has very narrow wiring, and it seems that I cannot connect it to the new receiver outputs (it slides out very easily). I do have another Denon receiver at my house, and JBL speakers that I've wired with 12AWG Enhanced Loud Oxygen-Free Copper Speaker Wire Cable, and it works great (I still have 50ft of this cable).
The 12WG cable is noticeably thicker than my old speakers cable. The main problem is that I cannot take out the cable from the old speakers and replace it with the 12WG cable (the cable is built in the speaker). Thus, I'm wondering if my old speakers are considered trash or there is a way to save the situation? (I would buy new speakers anyway, I just need to do some ceiling work before that, and it takes time that I currently does not have).
Thank for the help!
Moshe1010 is offline
post #2 of 3 Old 01-30-2013, 06:43 PM
skidog's Avatar
Liked: 27
If the speakers have extra wire just strip some more and fold it back on itself to make it thicker.
Panasonic TC-P65VT50
Denon 2113ci
Panasonic DMP-BDT220P
Ascend CMT-340SE L/R
Ascend CMT-340SE Center
Ascend CBM-170SE Surrounds
Klipsch RW12-D x 2
skidog is offline
post #3 of 3 Old 01-30-2013, 10:36 PM
afrogt's Avatar
Quoted: 1058 Post(s)
Liked: 761
You can't take the back cover off of the speaker?
You could either splice the 12ga into the thin wire or do what was suggested above, fold it over onto itself to make it thicker.
Afro GT
afrogt is online now
Reply Speakers
Denon Avr 2113ci Receiver
