Energy Take Classic 5.1 Crossover help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 01-30-2013, 04:24 PM - Thread Starter
sunnyav's Avatar
Hi All,
I have set the crossover on my Sony STR-DN1030 to "100 Hz" with Energy Take classic 5.1 system.
I have a questions based on the frequency response of speaker specs.
Sat: 115Hz-20KHz;
Center: 110Hz-20KHz;
Subwoofer: 33Hz-150Hz
As I have set the crossover to "100 Hz" and Center freqency is 110 Hz to 20KHz , am I going to miss some frequency because the lowest of Center is 110 Hz but I set my crossover to 100 Hz ?.
Please explain.
thanks,
sunnyav is offline
post #2 of 13 Old 01-30-2013, 04:36 PM
JD in NJ's Avatar
Liked: 36
While you probably won't entirely miss any frequencies from the center, you will quite possibly be down by some amount in that 100 to 110 range. How much it's hard to say, without measuring. For the satellites it will be slightly worse.
I am not familiar with your receiver, and don't know if it supports any kind of automatic EQ. If not, I suggest playing with the crossover setting. and repeatedly listening to the same sounds after each adjustment. If you can measure this, even better, otherwise go with what sounds best to you.
JD in NJ is offline
post #3 of 13 Old 01-30-2013, 05:04 PM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
The fundamental problem is that the front speakers of that system are simply too small to function as the front speakers.
They have main drivers (which they laughingly call "woofers") that are smaller than the speaker of a cheap clock radio.
Front speakers should go down to AT LEAST 80 Hz, preferably 60 Hz, so that the subwoofer only has to function at the the lower frequencies.
I suggest that you buy a pair of Sony SS-B1000 speakers, which have 5 1/2 inch drivers, and use them as your front pair of speakers.
Then you can set the crossover for 80 Hz for the fronts and sub, and the system will sound 100% better.
You can get those for only $60 per pair.
Or you could get a pair of Polk Monitor 30 speakers, which run $100 per pair or so.
Operating the Center at 110 Hz and up is correct; it should NOT operate at lower frequencies
Your front speakers must be able to operate down to 80 hz, and the ones you have are way to small to do it! You need larger ones. That is the only way to fix your problem IMO.
commsysman is offline
post #4 of 13 Old 01-30-2013, 05:30 PM
Saints's Avatar
Quoted: 14 Post(s)
Liked: 29
The OP came here to ask a question about what crossover to set, so why are you telling him to go buy some crap that he doesn't need? He never asked what speakers does commsysman think I need....
Set all of your crossovers to 120hz if your receiver will allow it for the takes. Your sub will handle everything below that.
Life is hard, be harder.
Saints is offline
post #5 of 13 Old 01-30-2013, 05:38 PM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1800
I'd either:
- set all the speakers to 120Hz; or
- set the sats to 130Hz and the CC speaker to 120Hz.
eljaycanuck is offline
post #6 of 13 Old 01-30-2013, 08:27 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
x2 Abd BTWs that's what that guy always does.
to the OP set it at 120hz for all speakers and forget about. I use to have a similar small speaker set-up Polk RM6750 with similar speaker rated performance and it recommended setting to 120hz. Though I did move it to 100hz as the system sounded better to my ears then
crazyrob425 is offline
post #7 of 13 Old 01-31-2013, 08:42 AM - Thread Starter
sunnyav's Avatar
Hi All,
Thanks for your valuable feedback. Now I have set my crossover to 120 Hz and I will test how this sound for next couple of days.
sunnyav is offline
post #8 of 13 Old 08-19-2013, 07:15 PM
beardontwalk123's Avatar
Quoted: 824 Post(s)
Liked: 547
Hello everybody : )
I am getting the Energy Take Classic 5 pack and the center channel is rated 110hz at the lowest and the rest are rated at 115hz at the lowest. I have a Klipsch sub that is rated 36-200hz......so my problem is that my receiver only goes from 100hz crossover to 150hz crossover. 150hz seems like too much......would it be bad for the speakers to set the crossover at 100hz and would I lose alot or should I have it set at 150? All speakers have 3inch woofers. Thank You
beardontwalk123 is online now
post #9 of 13 Old 08-19-2013, 07:21 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
try it at 100hz and 150hz then leave it at whatever setting sounds best to you. I have a hunch it'll be 100hz.
Afro GT
afrogt is offline
post #10 of 13 Old 08-19-2013, 08:13 PM
Quoted: 824 Post(s)
Liked: 547
Will it ruin the speakers if I set it to 100hz?
post #11 of 13 Old 08-19-2013, 09:54 PM
Gmash's Avatar
Quoted: 144 Post(s)
Liked: 142
You won't hurt the speakers. Like Afrogt said, just use whichever one sounds better to you.
Gmash is offline
post #12 of 13 Old 05-15-2014, 08:04 AM
hayabusa15's Avatar
I got the same question i have the energy take classic 5.1 and a denon e300 reciver whit audessy set up but i dont khow if this set up is right for me i have a small livingroom this is the audessey set up center speaker 80Hz,front speaker 80Hz and sat 60Hz subwoofer 120Hz is ok or not please help
hayabusa15 is offline
post #13 of 13 Old 05-15-2014, 09:43 AM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2986
Yes. Best to try this.
Originally Posted by eljaycanuck View Post
I'd either:
Leave the LFE setting for the subwoofer on 120hz.
Of course, if you like it better the way that Audyssey set it, then go for it. That's all that matters smile.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
Reply Speakers
Energy Take Classic 5 Pack 5 0 Home Theater Speaker Black , Energy 5 1 Take Classic Home Theater System , Energy Take Satellite Speakers Pair Black
