Stand recommendation for Kef iq30 speakers?!? - AVS Forum | Home Theater Discussions And Reviews
Old 01-30-2013, 06:53 PM - Thread Starter
marcmedz's Avatar
Hey everyone,
Was wondering if anyone could recommend some good quality stands for my Kef iq30 bookshelf speakers. The iq30's have a unique shape to them so that's why I'm unsure about what stands to look for. My price range I guess would be between $200 - $300, I hope that's fair confused.gif. Thanks in advance.
marcmedz is offline
Old 01-30-2013, 09:25 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3081
I would just get some Sanus 24" or 26" stands. They should be much less than your stated range unless you opt for some of the heavier metal stands.
marcmedz likes this.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
Old 01-31-2013, 08:05 AM
JimWilson's Avatar
Quoted: 1268 Post(s)
Liked: 1564
I've used the Sanus stands before, and thought the were pretty good.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
Old 01-31-2013, 08:37 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
You want stands that are:
Metal
Rigid and heavy
Have a center column that can be filled with sand or metal bird-shot for mass and damping (essential).
A metal fabrication shop can make them from a 3-inch tube and two plates, and you will have excellent ones at a low price. You can buy spikes to put on them separately.
The Lovan L-JA3BB-966 is an excellent one that is $230. It has excellent mass and rigidity and its 3-post design will handle even the heaviest speakers.
The Dayton SSMB-24 is not too bad for only $70.
commsysman is offline
Old 01-31-2013, 09:04 PM - Thread Starter
marcmedz's Avatar
nice, thanks for the suggestions everyone. that lovan stand is one hell of a stand, i really like it, looks solidly built and dependable. hey commsysman, are there any other stands of that quality (lovan) around the same price or maybe a bit lower? smile.gif
also, are those post welded on the lovan stands? because i definitely prefer something like that. thanks again.
marcmedz is offline
Old 02-01-2013, 09:51 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3081
Check out the Sanus steel or ultimate series stands. They're a bit pricier but built for heavier speakers.
Old 02-02-2013, 01:02 AM - Thread Starter
marcmedz's Avatar
cool, will do. thanks for the suggestion.
marcmedz is offline
Old 02-02-2013, 08:31 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
I think that the Lovan stands are all-welded construction.
Sound Anchors are another one.
That Dayton SSMB-24 is probably a good one for your speakers.
It is about the right size and only $65 from Amazon.
You can buy a bag of steel bird shot and fill the tubes to give them more mass.
Old 02-02-2013, 11:13 AM - Thread Starter
marcmedz's Avatar
ok great, thats good to know. thanks for your help commsysman, i'll definitely look into all these options. smile.gif
marcmedz is offline
Old 02-02-2013, 04:13 PM
K Shep's Avatar
Hey everyone,
I own a pair of Usher BE-718's and KEF LS50's for both I use Sanus: http://www.sanus.com/ap/en/products/speaker-foundations/sp-ultimate
I buy a bag of play ground sand from Lowes or Home Depot and fill the tubes. The stands come in different heights, you want the tweeter at ear level.
K Shep is offline
Old 02-02-2013, 11:57 PM - Thread Starter
marcmedz's Avatar
Ah, great. Good to know. Thanks for the advice, appreciate it.
BTW, do those sanus ultimate series stands have something to hide the wiring, cause i believe the series below the ultimate do have something.
marcmedz is offline
Old 02-03-2013, 02:37 PM
K Shep's Avatar
I think when you get to the "Ultimate" level you should be showing off your speaker cables and not hiding them. I am joking! but that's funny.
No cable channel on the ultimates.
K Shep is offline
Old 02-03-2013, 11:42 PM - Thread Starter
marcmedz's Avatar
haha, yeah i know right? thats kind of a bummer though, was hoping they did.
marcmedz is offline
