Good ceiling speakers to go with - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-31-2013, 08:49 AM - Thread Starter
Knuckles05's Avatar
I bought my house and the previous owner had ceiling speakers mounted. There are 4 circle cutouts. I'm not sure what size speaker he had but the cut out space is 8-8.5 inch. Looks like he ran a 5.1. I am planning to fil the holes in as I am tired at looking at them. Wanted to know what are some good speakers to put ceiling wise. I would need 4. Looking to spend no more than $1000. Also do you guys know if a speaker has a smaller cut out space size if it will still work or fit? I am looking at buying either a pioneer receiver or Yamaha. Please let me know what you guys would recommend. Thanks. Any tips or advice on speaker or home theatre would be much appreciated.
Knuckles05 is offline
Reply Speakers
