3.1 Setup on a budget. How did i do? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-31-2013, 10:24 AM - Thread Starter
Jestoner's Avatar
First of all thank you all so much for all your info! This site combined with a few other resources helped me out a great deal while deal hunting.
I hate to be one of those "is what i bought good?" guys but... could anyone perhaps answer this exact question? I would just like to know if i screwed up anywhere so i can bring anything back during the return period.
-I got a Harman Kardon AVR-1700 open box at best buy for $150
-While at best buy and perusing their open box items i also found a pair of Polk T15's for 35 bucks.
-Based on these polks and suggesting to match cone size etc i grabbed the polk CS10 center channel at full price from amazon
-For a sub and based on a few suggestion i grabbed a BIC America F12 with the idea i won't have to upgrade for a while
Basically I'd like to know if i made any mistakes or if i could have gotten a better bang for my buck anywhere. Also sorry if this is not where i should be posting this.
Jestoner is offline
post #2 of 9 Old 01-31-2013, 10:45 AM
cel4145's Avatar
Quoted: 2657 Post(s)
Liked: 2987
That's a fantastic deal on the 1700 for $150. Sounds like you set yourself up really well for so little money smile.gif
If you want to save $20 and it's not too late, you can get the Polk 15C from Newegg for $89 shipped. That's the update to the previous Monitor model series that the CS10 was used with.
Meanwhile, Polk recommends the CSR with the T15, and it's $55 on Newegg. But you bought a better grade of center. That would be nice should you ever want to upgrade your fronts to the Monitor series and move the T15 to the rear.
BIC F12 is one of the best subs for HT for around $200. Can't go wrong there smile.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #3 of 9 Old 01-31-2013, 12:02 PM - Thread Starter
Jestoner's Avatar
Yes i was very excited about the Receiver. To anyone looking for a similar deal use the best buy store locator and pick your store. From here you can view open box and clearance items. Also keep in mind the longer an item sits as open box the cheaper it goes and the more likely it will be that they'll knock down the price further. I have 2 best buys equal distance apart. One had this unit for $480 and one had it for $180. I asked a manager if he could do better than 180 and he marked it down a bit then they had a 10% coupon on all open box items that also applied.
Jestoner is offline
post #4 of 9 Old 01-31-2013, 01:31 PM
cel4145's Avatar
Liked: 2987
I have an HK 3390 stereo receiver in my home office, and I used to use an HK AVR35 in my HT setup. I really do like the HK sound. Assuming that model is similar, I'm sure you'll enjoy it.
Have you hooked up the HK and the T15s? No reason not try them out smile.gif
cel4145 is offline
post #5 of 9 Old 01-31-2013, 01:35 PM - Thread Starter
Jestoner's Avatar
I have but just mainly to text that that everything worked. The problem is i tested them with an MP3 off a jump drive and probably didn't use the best music. Combine this with the fact that i didn't have anything of any quality to test from as a base i am kinda blindly deciding if i like what i hear. That being said it did sounds pretty darn good and the sub/center channel has yet to arrive. I have my basement completely torn apart as i am building an entertainment center in to the wall so i am limited in what i can test. Just picked up a Panasonic 50 inch UT50 as well and i think i will be very pleased with my setup considering i stayed under my $1500 budget.
Jestoner is offline
post #6 of 9 Old 01-31-2013, 01:38 PM
cel4145's Avatar
Liked: 2987
I have the 50" UT50. It's awesome!
cel4145 is offline
post #7 of 9 Old 01-31-2013, 01:42 PM
GaryWA's Avatar
Quoted: 16 Post(s)
You should run speaker wire through the walls before you put the drywall up. Make sure to use CL2 rated wire though.
GaryWA is offline
post #8 of 9 Old 02-01-2013, 05:25 AM - Thread Starter
Jestoner's Avatar
Actually that's the exact reason i currently have the basement torn apart. I'm fairly new to DIY home repair/remodeling so i figure this will be good practice.
Jestoner is offline
post #9 of 9 Old 02-01-2013, 01:16 PM
border411's Avatar
My F12 is one of the best speakers (subs) I have ever heard. It is awesome.
~Shaun
Yamaha RX-V765 / PSB B5's Fronts / PSB C4 Center / Micca R-65 In-Ceiling Rears / BIC F12 Sub
border411 is offline
Reply Speakers
