best floor standings for 200-250 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-31-2013, 01:54 PM - Thread Starter
spoonx's Avatar
what are the best floor standing speakers i can get for around $200 each, then could you tell me a good pair rears to go with them.
spoonx is offline
post #2 of 9 Old 01-31-2013, 02:07 PM
JerryLove's Avatar
Liked: 82
Infinity P363. Infinity P163. Enjoy.
JerryLove is offline
post #3 of 9 Old 01-31-2013, 03:12 PM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
For that price range, the Polk R300 is what I would get. They are around $100 each.
For rears, get the R150, which are about $120 per pair.
The CSR is the matching center speaker, for about $80.
commsysman is offline
post #4 of 9 Old 01-31-2013, 03:53 PM
JerryLove's Avatar
Liked: 82
Presumably, at this point, every reasonable (and some unreasonable) pair of sub $200 speakers on the market will be suggested by their proponents.
Along with some people suggesting speakers past your budget, then a discussion of used; and in the end you'll have no more information that you did in the beginning and have to go listen and make a choice.
Congratulations on your decision (whatever it happens to be when you make it). I'm sure you will enjoy them.
post #5 of 9 Old 01-31-2013, 04:23 PM
zieglj01's Avatar
Quoted: 1714 Post(s)
Liked: 1632
Boston A360
http://www.accessories4less.com/make-a-store/item/BOSA360WHA/BOSTON-ACOUSTICS-A360-3-Way-Dual-6.5in-Tower-Speaker-Each-White/1.html
What is the budget for the rears?
__________________________________________
Who AM I
Speakers -- Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is offline
post #6 of 9 Old 01-31-2013, 04:27 PM
Mr.SoftDome's Avatar
Quoted: 499 Post(s)
Liked: 400
Why do people always think they need floorstanders when they are on extremely tight budgets? Why not bookshelf/monitors in this range?In my opinion you are going to get a better speaker with a tight budget over a floor stander.
But that's me.. when your budget rises then I guess it's a better argument as room size, music vs HT blah blah blah...
Heck, I use mointors and a great sub and I am thrilled. And my budget was not confined and I had options. The monitors still won out over many many tower contenders (with REL sub).
For $500 or less I would buy these but once again you have to do what you think is best.
Are these the best in the Focal line, no of course not but I certainly would entertain them for under $500. And Focal is totally respected speaker mfg.
Though shall not fear bookshelf/monitor biggrin.gif and this is just my thoughts and opinion. You want towers and think that is best for you then by all means go that direction.
http://www.musicdirect.com/p-41245-focal-chorus-705v-bookshelf-speakers-pr.aspx
Good Luck
Rick
Mr.SoftDome is offline
post #7 of 9 Old 01-31-2013, 04:30 PM
Quoted: 499 Post(s)
Liked: 400
And this is okay that you are suggesting but for new folks it should be a disclaimer that this site is B stock or slightly dinged goods or returns. Is it not? He may not understand that.
Rick
post #8 of 9 Old 01-31-2013, 04:50 PM
crazyrob425's Avatar
Quoted: 445 Post(s)
Liked: 339
Polk Monitor 70's or Monitor 75t's
Infinity P363's too
crazyrob425 is offline
post #9 of 9 Old 01-31-2013, 04:52 PM
cyde01's Avatar
Rick
Those Bostons are brand new in box with a huge discount on the white speaker finish.
cyde01 is offline
Reply Speakers
