Failed Tweeters, Replacement? - AVS Forum | Home Theater Discussions And Reviews
Old 02-01-2013, 09:03 AM - Thread Starter
The Birdman74's Avatar
I have some WHARFEDALE Diamond speakers here but all of their tweeters are dead, I am thinking if I could replace the tweeters? or maybe switch them with any smaller speakers? I
The Birdman74 is offline
Old 02-01-2013, 09:57 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Originally Posted by The Birdman74 View Post
I have some WHARFEDALE WH1.1 8ohm speakers here but all of their tweeters are dead, I am thinking if I could replace the tweeters? or maybe switch them with any smaller speakers? I have some Cambridge Computer speakers given to me by a friend and they have small speakers in them? they are 4ohm and 10w, but can they be used as tweeter replacements? otherwise anywhere I could get proper replacements for my speakers? cant spend alot fixing them but is anybody here have any spare tweeters that may work and I could have then let me know. I will be more then happy to pay as well. But need about 3 working tweeters.
Here are some web sites that sell lots of different kinds of tweeters:
http://www.parts-express.com/cat/speaker-components/4
http://www.madisoundspeakerstore.com/tweeters/
http://www.speakercity.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=SC&Category_Code=D
Often manufacturers are very happy to sell you exact replacements for reasonble prices. Contact Wharfdale first!
arnyk is offline
Old 02-01-2013, 06:03 PM - Thread Starter
Thanks Arny, I contacted Wharfdale, maybe they will respond after the weekend.
Anyway I see these tweeters can get quite expensive. Maybe I better look for new speakers altogether and sell these for what I can get. Any recommendations?
Is there anyway to fix my existing ones though? Or anybody here got any extra ones laying around?
Old 02-01-2013, 06:43 PM - Thread Starter
also could I use any tweeters from any other cheap speakers or something? does the ohm or watts matter? I found some used Japanese Tweeters for sale I may be able to get 3 for $10 - $20.. So was wondering if they will be a good enough replacement or if there is something I should watch out.
Old 02-01-2013, 06:49 PM
JerryLove's Avatar
Liked: 79
It's not likely to break anything (though possible), but it's also not likely to sound good using random tweeters. They may not be stable to the crossover, they may have a different efficiency than the mid driver, etc.
JerryLove is offline
