+ and - of speaker cables touched each other.and onkyo shut down itself - AVS Forum | Home Theater Discussions And Reviews
Old 02-02-2013, 09:55 AM - Thread Starter
fulhamx5's Avatar
i m newbie about hifi.
i ve purchased an onkyo cr n755 and a pair of dali zensor 1
i dont use banana plugs. and i didnt notice open ends of + and - cables touch each other.
onkyo shut down itself after 10 seconds music play automatically.
i didnt understand and run it again. and it shut down again.
is it a protection of onkyo?
fulhamx5 is offline
Old 02-02-2013, 10:21 AM
JerryLove's Avatar
Liked: 79
Yes. You have a short. That's damaging to equipment. The shutdown is for self preservation.
You need to fix that short. It is a fire hazard and a danger to your electronics.
JerryLove is offline
Old 02-02-2013, 11:32 AM - Thread Starter
fulhamx5's Avatar
ok i solved it after 3 times shutdown.
now they dont touch each other.
do u think it gave damage to my equipment?
it s working properly now
fulhamx5 is offline
Old 02-02-2013, 11:53 AM
JerryLove's Avatar
Liked: 79
No way to be entirely certain: but if it's working then it's working smile.gif
Old 02-02-2013, 12:06 PM
rdclark's Avatar
Quoted: 285 Post(s)
Liked: 544
And he's very lucky.
(I don't remember ever seeing an AVR or amplifier owner's manual that wasn't very explicit about not shorting the speaker wires.)
Wide Awake
on the Edge
of the World
rdclark is online now
Old 02-02-2013, 12:18 PM - Thread Starter
fulhamx5's Avatar
wish it didnt damage
all functions working properly
fulhamx5 is offline
Old 02-02-2013, 04:12 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Get some banana plugs and you'll have less chance of shorting your wires.
http://sewelldirect.com/Sewell-Deadbolt-Banana-Plugs-2-Pair-.asp
Afro GT
afrogt is offline
Old 02-02-2013, 05:51 PM
Class A's Avatar
Quoted: 295 Post(s)
Liked: 316
I had Thiel 2.3's which had the speaker connections on the bottom of the speaker. I brushed up against on of them the cable came loose and they touched. It fried one of my amps and it cost about $350 to fix.eek.gif
Class A is offline
Old 02-03-2013, 01:17 AM - Thread Starter
fulhamx5's Avatar
but i think new and high end brand amps have protecitons against this problem.
pioneer and onkyo for example
fulhamx5 is offline
Old 02-03-2013, 03:40 AM
rdclark's Avatar
Quoted: 285 Post(s)
Liked: 544
Protection circuits are standard on pretty much all amplifiers, but repeated shorts will weaken electronic components. You're lucky your AVR still works, but a little common sense goes a long way. Also reading the manual.
Wide Awake
on the Edge
of the World
Old 02-03-2013, 04:46 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
I don't know why you are advertising this lack of common sense.
Fix the short for goodness sake!
There is a good chance that the receiver is not damaged.
arnyk is offline
