which cable for onkyo cr-n755 and dali zensor 1 ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-02-2013, 04:37 PM - Thread Starter
fulhamx5's Avatar
i have a low quality cable without banana plugs .cable brand name is cadence.it came as a gift with speakers.
do u suggest me purchasing quality cable as QED xt anniversary for example? and do i have to use banana plugs? some people dont suggets using plugs.
thank u
fulhamx5 is offline
post #2 of 2 Old 02-02-2013, 04:42 PM
Bill Fitzmaurice's Avatar
Liked: 4663
There's no such thing as 'quality' cable, copper is copper, and you don't need connectors. You do want a gauge sufficient for the length of wire used and impedance of the speakers; this calculator will tell you what you need:
http://www.bcae1.com/images/swfs/speakerwireselectorassistant.swf
Bill Fitzmaurice is offline
Reply Speakers
