Noob needs some advice - 1000-1500k - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 02-03-2013, 02:14 AM - Thread Starter
l0pht's Avatar
I'm looking at a new home theater system, with a limit of around $1500 or less. Room is 8h 14w 14l and the length of the room opens up into a dinning area. The total length is probably 40 feet.
A couple gotcha's - one, the speakers and receiver needs to be able to handle dual voltage. I'm currently overseas with the military and don't want to rely on a transformer. After a quick look the Yamaha receivers seem to handle 110v/220v if you get the world models. Two - I'm looking for a 5.1 system. I really like the DT ProCinema 600s but I believe they are only 110v so I'm looking for another option. I run all my media through a Mac Mini, no BlueRay player (everything gets ripped) and have a Wii. Everything is displayed on a Samsung 6000 series LCD.
Also I don't want anything huge.
I'm fairly new with home audio setup so I'm still reading up on all the options and learning lots.
l0pht is offline
post #2 of 14 Old 02-03-2013, 05:41 AM
smasher50's Avatar
Quoted: 355 Post(s)
Liked: 15672
fwiw, whats the reasoning of not relying on a voltage transformer/ converter. thats what they are made for.
i'm so laid back,i'm laid out
smasher50 is online now
post #3 of 14 Old 02-03-2013, 05:55 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
The reasoning is that some of them have built in safety hazards and have killed people. One thing to avoid are the cheaper ones that are "auto transformers" and not isolation transformers.
If you buy a good one, it is merely a little inconvenient. When I had the problem I went with a good transformer and all was well.
arnyk is offline
post #4 of 14 Old 02-03-2013, 07:25 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 522
Since the speakers are passive, except for the subwoofer, all you would have to do when you return to the states would be get a new subwoofer. The speakers don't care what voltage the receiver is running off of...lol.
That would be a perfect opportunity to upgrade, since the subwoofer that comes with those small speaker systems are not very good anyway.
commsysman is offline
post #5 of 14 Old 02-03-2013, 07:33 AM - Thread Starter
l0pht's Avatar
That's what I'm looking for. So what do you suggest???
l0pht is offline
post #6 of 14 Old 02-03-2013, 07:49 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 522
Most of the small package systems are pretty weak, because they have 2.5" or 3" main drivers in the front speakers. Way too small for your room.
I would want to get a pair of front speakers that have drivers that are at least 5 inches/130 mm in diameter.
Then get a matching center speaker and a pair of compatible rear speakers.
It's hard to know what you have access to there , or what prices are like.
What brands or systems can you get?
KEF stuff is nice.
Maybe you can find a subwoofer that has a dual-voltage switch on it, so you can bring it back?
post #7 of 14 Old 02-03-2013, 08:00 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 522
The Definitive Technology Studio Monitor 55 is an EXCELLENT speaker, and sell for $598 per pair in the USA.
If you can get a pair of those, jump on them.
They are large enough for your room, and you can add a center and satellite speakers to go with them.
The DT ProCenter 1000 would be good for the center, and the ProMonitor 800s for satellites.
That system would be about $1000 in the USA, but your prices may be quite different.
The front speakers are where 90% of your sound comes from, so they are JOB ONE!
post #8 of 14 Old 02-03-2013, 08:55 AM
Elihawk's Avatar
Quoted: 1015 Post(s)
Liked: 860
To add to commysman suggestion, the speaker that the sm55 replaced, the SM 350/450 have huge discounts in pricing right now. You can get a pair if sm350s for 170! I have that speaker (and the sm450s) and that is one excellent speaker, for the money.
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
post #9 of 14 Old 02-28-2013, 11:22 AM - Thread Starter
l0pht's Avatar
What KEF speakers would you recommend?
l0pht is offline
post #10 of 14 Old 02-28-2013, 11:23 AM - Thread Starter
l0pht's Avatar
Keep in mind I want bookshelf style (they needs stands though) speakers.
l0pht is offline
post #11 of 14 Old 02-28-2013, 11:38 AM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2989
Since you are overseas, are you looking for speakers that you can purchase where you are? Or are you going to buy in the US and have them shipped overseas (I am assuming you are US military)?
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #12 of 14 Old 02-28-2013, 11:47 AM - Thread Starter
l0pht's Avatar
I have an APO so buying them from the US is possible and probably cheaper but can also buy them in Germany.
l0pht is offline
post #13 of 14 Old 02-28-2013, 12:10 PM
JohnE5's Avatar
On that same topic I'm looking at the SM45s and am now intrigued with the SM450s. If I can save $100 on the pair I'm going that direction if the difference between the two sets of speakers are not that different.
My question is what is the comparison between the outgoing and current offerings? I know the 450s have larger drivers (6.5" vs the 45s 5.25") and the addition of a bass radiator. Is it just a visual change?
Also, what center channel goes with either the SM45 or SM450? The CS-8040hd, ProCenter 1000, or Procenter 2000? The LCR center channel that paired with the 350/450 is discontinued.
Your Thoughts?
John
JohnE5 is offline
post #14 of 14 Old 02-28-2013, 12:32 PM
cel4145's Avatar
Liked: 2989
In that case, I'll recommend the Ascend Acoustics CBM-170 SE, CMT-340 SE center, and HTM-200 SE for surrounds.
Reply Speakers
